shifter shims between levers - NCRS Discussion Boards
  • Joe B.
    • October 6, 2014
    • 5
    I have taken my shifter apart and have a shim I'm not sure where it goes. Its a thin shim less then a 1/16". It's OEM 4-speed.
    I'd appreciate any help I can get here! Joe
  • Mike M.
    • May 31, 1974
    • 8409
    Re: shifter shims between levers
    it goes between reverse lever and the 1-2 lever. mike
    • Mike M.
      • May 31, 1974
      • 8409
      hold off on the above advice. i'm installing the rebuilt shifter on a midyear muncie and having troubles. think i may have mis-placed the shim. will get back to you in an hour or so. sorry, mike
      • Mike M.
        • May 31, 1974
        • 8409
        i was correct in my initial post. the shim technically referred to as an interlock, is positioned between reverse lever and the 1-2 lever. mike
        • Joe B.
          • October 6, 2014
          • 5
          Thanks Mike appreciate the help. Joe
            • 43292
            Here's a diagram of the 1964-67 4 speed shifter. It's basically the same as C3.
              Here's that interlock, between the reverse and 1-2 levers.
