63 distributor drive gear - NCRS Discussion Boards
  • Richard S.
    • April 1, 2003
    • 288
    I have a 63=327=340HP. Can some one tell me if the distributor drive gear is the same for the 250-300-340 and 360 HP engines
  • Mike M.
    • May 31, 1974
    • 8383
    Re: 63 distributor drive gear
    same. mike
    • Richard S.
      • April 1, 2003
      • 288
      The response is not what I am looking for. The response reference is for transmissions. My questions is for distributor drive gear.
      • Dan H.
        • July 31, 1977
        • 1369
        I'll have some of what Richard is smoking.
        1964 Red FI Coupe, DUNTOV '09
          • 43220
          Richard-------
          The distributor drive gear is the same for ALL 1963 Corvette engines as well as all other 1963 Chevrolet V-8 engines. As a matter of fact, while several different successive part numbers were used over the years, the 1955-86 drive gears for all Chevrolet V-8 engines are interchangeable. The last available part number, GM #1958599, has been discontinued without supercession.
          • Mike M.
            • May 31, 1974
            • 8383
            are you talking about the ignition distributor drive gear or the speedometer drive gear on the tailshaft of the tranny. and if you are talking the ignition gear , are you inquiring about the drive gear(driven by the camshaft) or the tach drive gear. mike
            • Dan H.
              • July 31, 1977
              • 1369
              Please someone tell me where transmissions were referenced. Mikes response was spot on!
              • Stuart F.
                • August 31, 1996
                • 4676
                Did all distributor drive gears have the same pin hole diameter, let's say from the 1955 thru 1986, being as how the pin changed from a tapered pin to a roll pin??? Having a 57 distributor, along with my 63 and an aluminum body one of unknown aftermarket replacement origin in my parts stock, the only difference I can see is the pin.
                Stu Fox
                • Michael G.
                  • January 1, 1997
                  • 1251
                  Hey.........don't bogart that bong friend!
                    • 43220
                    Stu Fox
                    Stu------
                    I'm not familiar with the tapered pin gears. However, the thing I can't figure out is how the GM #1958599 could SERVICE back to 1955 if there was a difference in pin size/configuration for the early distributors.
                    • Stuart F.
                      • August 31, 1996
                      • 4676
                      I do believe I could replace the tapered pin now in my 57 distributor with a roll pin, but I never did. I had the tapered pin out at some time in the past, but replacing it was not easy apparently. I must have had trouble driving it all the way in as I ground off the end. It's kind of hard to remember what you did and why over 50 years ago. I know I replaced the plate and I've kept it around as a spare. It is sort of work of art, what with it's oil pipe with snap cap, etc.
                      Stu Fox
                      • Richard S.
                        • April 1, 2003
                        • 288
                        Thanks, the older string of threads relating to the distributor drive gear index is what I was looking for.
                        Rich
