engine noise - '66 427 - NCRS Discussion Boards
  • Stephen L.
    • August 29, 2007
    • 205
    so, out of nowhere, i am driving and start to hear a clunking sound from the engine...engine speed slower, clunking sound occurred less frequently... engine speed faster clunking sound occurred more frequently
    i stopped driving immediately
    any thoughts???
    • 43219
    Re: engine noise - '66 427
    any thoughts???
    Stephen-------
    Lots and lots of possibilities from the relatively benign to the calamitous.
    The first think I'd check is possible interference between the flywheel and the flywheel cover. Sometimes the cover will get slightly distorted and contact the flywheel.
    • Doug M.
      • January 1, 1991
      • 68
      Remove valve covers, check rockers and push rods
      • Stephen L.
        • August 29, 2007
        • 205
        Thanks Guys - will start with this ...
          • 15667
          any thoughts???
          Are you sayilng that the frequency of the "clunking" is tied directly to engine speed? If it occurs at idle can you get a general idea of where it is coming from. You haven't provided much to go on.
          Other things to check are the front balancer bolt and all pulley bolts. Try moving all the pulleys fore/aft with the engine off. Any play could mean a loose pulley or worn bearing in the driven accessory. For example a worn coolant pump bearing will result in such movement of the pulley. Do the same check for the viscous fan clutch.
          • Joe C.
            • August 31, 1999
            • 4598
            A dead miss can cause this kind of noise in a worn engine.
            • Stephen L.
              • August 29, 2007
              • 205
              Thanks guys - question one is should I even start the car to diagnose or can I risk doing more damage ?
              Engine is the cars original 390h engine with its original stamp on stamp pad - can't afford to lose it !!??
              • Stephen L.
                • August 29, 2007
                • 205
                [QUOTE=Duke Williams (22045);726665]Are you sayilng that the frequency of the "clunking" is tied directly to engine speed? If it occurs at idle can you get a general idea of where it is coming from. You haven't provided much to go on"
                yes Duke frequency of clunking is tied directly to the speed of the engine
                i don't have much because I went immediately home so as not to mess things up further
                if I had to guess, sound was at front to left of front of engine - perhaps even left side - but really guessing at this point
                • Anthony P.
                  • October 26, 2011
                  • 199
                  When I hear the description as clunky I assume lower end but in this case a broken fuel pump spring can make an rpm related click/tap noise also! left front of the engine, just another opinion!
                  • Edward B.
                    • March 29, 2013
                    • 691
                    Before tearing into things, remove the belts and see if the clunking goes away. I've had water pumps make clunking noises because of bad bearings before, and the noise was hard to pinpoint. Removing the belts will at least rule out the accessories.
                    Ed
                    • Stephen L.
                      • August 29, 2007
                      • 205
                      thanks guys
                      here is what i did
                      started car and let it idle until it got up to temp - idled at 1500 ... no noise - idled at 2500 ... no noise
                      bit the bullet and decided to drive the car
                      no noise at first, but sure enough clunk appeared - but tested it further...interestingly, it did not go up and down with engine speed...but with car speed
                      in fact, it turns out that it is not in the engine at all
                      it is somewhere in the left wheel, steering gear box area
                      if i turn to the left, it is there - go straight it is there - turn right...nothing
                      what are the thoughts now?
                      again, it is kind of a clunking noise - you can also feel it in the steering wheel
                      thanks!
                      • Patrick B.
                        • August 31, 1985
                        • 1995
                        Jack up the front end and wiggle the wheels with your hands. Might be a front wheel bearing.
                          • 15667
                          If the frequency goes with wheel speed my first suspects would be a loose wheel or brake caliper or maybe even a cracked brake disk. Check those first then check ball joints, A-arm bushings, all steering joints for play, and all related fasteners for proper torque.
                          • Edward B.
                            • March 29, 2013
                            • 691
                            I'd guess a wheel bearing, which, luckily for you, will be a LOT cheaper than engine issues!!
                            Ed
                            • Stephen L.
                              • August 29, 2007
                              • 205
                              thanks guys
                              yes, SUPER relieved it does not appear to be an engine issue
                              will start to look at the front end and see what i see
