396 at the upcoming Mecum Anaheim auction - NCRS Discussion Boards
  • Chris H.
    • March 31, 2000
    • 837
    Anyone familiar with this car? Looks to have a very interesting history. https://www.mecum.com/lot-detail.cfm...=AN1114-204779
  • Jody B.
    • February 28, 1991
    • 108
    Re: 396 at the upcoming Mecum Anaheim auction
    You would think that they would have installed the wipers correctly.....
    • Michael J.
      • January 26, 2009
      • 7077
      • Mike T.
        • December 31, 1991
        • 568
        Curious as to what rear gear ratio it has. The NCRS Spec Guide shows 3:36 as the standard ratio for the 396 in 65 but a 3:08 was available. If it had 3:36's, depending on tire size he had back then, it seems he had to be buzzing it up near 6700+ rpm to hit that speed.
        Mike T. - Prescott AZ.
        • Wayne M.
          • February 29, 1980
          • 6414
          Another thing; in addition to the 3.08's, if you ordered the 36.5 gallon option (N03) you got the rear wheelwell filler panels that permitted tires up to 8.15 x 15.
          I may be imagining things, but I can see the forward edge of the tank cover between the seats. [the horizontal line just below the rear view mirror -- cover is half in the shade (between seats) and in the sun (the horizontal part).
          If so, I can't understand why Mecum hasn't mentioned this.
          • Bruce B.
            • May 31, 1996
            • 2930
            In Mecums infinite wisdom they only print the info that is supplied by the owner, liability you know.
            But if there is a big tank the owner is obviously missing the boat...
