Second design parking brake lever 65-66 - NCRS Discussion Boards
  • Randy S.
    • January 1, 2003
    • 586
    In April 66 Chevrolet introduced a second design parking brake lever #3899399. The original lever was 3842938. The design was to increase mechanical advantage. My Feb 66 car is 2 months prior to the change (Vin 6S118091 acccording to the TSB)
    Before I adjust the parking brake, is there anyway to identify the second design, i.e., distance between holes etc.?
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Second design parking brake lever 65-66
    For the benefit of those who are not familiar with the Tech Service Bulletin, here's the 2 pages: If you can trust the drawing to be to scale, you could calculate the distance between the holes.
    c
    • Jim S.
      • March 1, 1986
      • 1408
      Randy ,
      Does this help? . As near as I can see , it is 6 inches center to center lengthwise and 1 inch center to center from pull rod hole to pivot hole .
      Jim
      • Randy S.
        • January 1, 2003
        • 586
        Jim,
        Big help. Thanks. My lever is attached to the bottom of the bracket so I cannot see the notch but I can feel it. So I have to assume it has been upgraded to second design.The long arm of the lever is 6" center to center of holes.
        Randy
        • Wayne M.
          • March 1, 1980
          • 6414
          Here's the arm and the frame bracket (without the notch shown in the TSB) on my late '65. Hard to see a difference in the installed arms without a side-by-side comparison.
          Since the pivot bracket is welded to the frame X-member, I wonder if the notch was done at St. Louis, or at the frame fabricator.
          • Bill W.
            • March 1, 1980
            • 2000
            Wayne I would say any car built before 4/1/66 was was modified at the dealer only if the owner complained . The bulletin was sent to the dealers in May showing the repair needed . Many times the factory made changes based on the modifications we had to do at the dealers . Bill
