63 oil filter center bolt leaks ? - NCRS Discussion Boards
  • Robert B.
    • March 1, 1992
    • 265
    what would make the oil leak from the center bolt area on oil filter canister ?
    Re: 63 oil filter center bolt leaks ?
    Robert -
    Missing copper washer under bolt head, distorted canister surface under washer, bolt loose, etc.
    • Michael H.
      • December 1, 1987
      • 733
      Not torqued correctly. 20-25 Ft Lbs.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11366
        If it is the copper washer, there is a repair kit available to fix it. Most vendors have it.
        I've used these many times with "dripless" success.
        Rich
        • Tom H.
          • December 1, 1993
          • 3440
          Washer. Were they copper or brass ??
          Tom Hendricks
          Proud Member NCRS #23758
          NCM Founding Member # 1143
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11366
            Tom, Where've you been? Hope all is well!
            They're copper. Here's a original, and the kit....LIC #38-11C, and most vendors have it as well. The tube is just to install the new push-clip.
            • Tom H.
              • December 1, 1993
              • 3440
              Thanks ! I'm still around ! Mostly read and learn. Help the C4 guys when I can.
              Tom Hendricks
