Re: Vacuum reading at idle 63-327-340 HP
Okay good, I understand, thanks. Sorry if I got a little postal.
Well, I guess we can have a little bit of "base-engine" intermission until we hear back from the OP. What you explained is just what I was thinking about the base setup. Makes sense. When I pulled the distributor for the intake manifold change and saw the B26 I was surprised. I expected a B22. Plus when I tested it it was all in around 10", even more aggressive I thought. But maybe my vacuum gauge has gone bad at higher readings, it's quite old. I haven't heard back from Lars yet about his B26 VAC choice. However, I got the numbers from the car owner's paperwork.....
"B26 Vacuum Advance"
"20* centrifugal advance"
"Set timing to 16* below 700 RPM, or set for 36* total"
"Vac Adv starts at 6", Full Vac Adv 13* @ 13"
What's very confusing to me is the fact that the base 250hp timing spec is 4*, and he's saying to set to 16*.
I set static(no VAC connected) to 4*, ran it up and it ran very well. Connected vac and saw about 20* on the dial back. Normalized the temperature and verified around 180* operating. Took the car for a ride and it was perfect. A few WOT bursts and it was good. Brought it back and idled for a long time cool and comfortable. Since he DRIVES his cars here in Florida heat, he added A/C, and even with that on the car still runs cool.
This is my query to him.....
Are you stating to set timing to 16* (with VAC can hose plugged)?
i.e. ...........
16*static + 13*(vac adv actual) + 20* (centrifugal) = 49* total timing
Or.....Are you stating to set timing to 16* (with VAC can hose connected)?
i.e. ...........
4*static + 13*(vac adv actual) + 20* (centrifugal) = apx 36*(actual 37*) total timing
Also, You used a B26 VAC. It's specs state starts at 6", all in at 12".
The B22 VAC starts at 8", all in at 15". Would that have been closer to get the "2 Inch Rule" since Frank's idle vacuum is around 20"?
edit...........
I found a thread on CF where he explained why. The distributor had a hi-perf baseplate with the smaller slot for the VAC arm. Rather than opening the slot and using a B22, and since he wanted 36* total, he used the B26 (13* spec). Here's his explanation....
Frank's distributor had the stock, hi perf short advance slot in it, which resulted in a 16-degree initial spec to achieve 36 total. I could have machined the slot longer, but the 16 degree initial spec actually tends to work pretty well when combined with a 12-14 degree vacuum advance: This produces actual idle timing of about 30 degrees, which is about as perfect as you can get.
Yes, I replaced the vacuum advance control unit with a B26, limited to 13 degrees.
Mystery uncovered.....
Well, I guess we can have a little bit of intermission until we hear back from the OP. Plus it keeps his thread up on top of the heap.
Yes it's a better method to start another thread with your question, and we've discussed that at length many times. Copy/Paste this string in the Advanced Search for lots of info. holley AND ported AND vacuum AND ( OR L71* OR L79* OR L68* 435 OR 400 )
I know how to drill out the Holley L71 center carb thanks to others here, but not sure about your L79 unit. It may be similar. If you start another thread and I bet those-in-the-know will jump in.
Hmmm, I get frustrated getting involved in threads and never get replies from the OP's. I have a list of about 5 or 6 threads on here and the CF where they never return. Hopefully not for serious reasons.
Richard, the OP......where are you? We're all waiting. Sorry we got a little sidelined with unrelated jargon(me especially
), but we're all here to help you get your answers. Plus it helps others in the future when they search the archives in here.
John, did you ever test your MS 201-16. I tested one once and it was way out of spec. It was a used one and likely just a defective or worn out spring, but NOS has old rubber diaphragms inside and wondering if yours is still good. Too bad they're sealed units, so we could change diaphragms and springs and still retain the external appearance. Hmmm, Frank A. can do that to CSV's, I wonder if he can do that the VACs?
Rich
i.e. ...........
i.e. ...........
edit...........
), but we're all here to help you get your answers. Plus it helps others in the future when they search the archives in here.John, did you ever test your MS 201-16. I tested one once and it was way out of spec. It was a used one and likely just a defective or worn out spring, but NOS has old rubber diaphragms inside and wondering if yours is still good. Too bad they're sealed units, so we could change diaphragms and springs and still retain the external appearance. Hmmm, Frank A. can do that to CSV's, I wonder if he can do that the VACs?
Rich
 He's going to have alot of catching up to do......
 I then repaint the engine by hand with a 1" artist fine detail brush because I didn't want overspray anywhere, etc, etc.
