Air filter element A353C application. - NCRS Discussion Boards
  • Michael K.
    • January 14, 2013
    • 99
    Does anyone know the correct year and engine hp this element is for? Thanks all, Michael Kalogridis
  • Michael K.
    • January 14, 2013
    • 99
    Re: Air filter element A353C application.
    Just found info in archives. Looks as though it is for the dual snorkel 250hp. If I am wrong let me know. Otherwise I believe I am good. Sorry to take the space, mk
    • Harry S.
      • July 31, 2002
      • 5330
      MK, as far as I know that part is a Service Replacement. Wasn't the original a metal ring wrapped in foam. Then oil was put on the foam. I'll see is I can find a picture.Found them. In the second picture the one on the left is original, the other one is the repro.
        • 43247
        Michael-------
        AC A353C, aka GM #6484339, was a SERVICE-only, paper element applicable to 63-65 Corvette small blocks with carburetors. It is no longer available from GM.
          • 15706
          It was also used on a Cadillac application. Unfortunately Baldwin does not make a replacement, but I believe the NAPA 2070 or equivalent will work for the application.
          It's a little short on total filter area compared to the later open element type air clearners that use a taller filter element, which is probably why the foam element was used, but I only recommend it for judging as it will result in a continuous "dirt hone" if you use the foam over long duration because the foam has poor filtration compared to modern cellulose filter materials.
          One of these days I want to see a chassis dyno test comparing the foam to cellulose to see if there is any measureable change in top end power.
            • 43247
            Duke------
            Yes, it is also applicable to 1967 Cadillac as well as a few other obscure applications. As far as Corvette goes, though, only 1963-65 small blocks with carburetors. The only current manufacturer I can find is Wix under their number 42070 which, of course, may be sold under other brands. Fram and Purolater do not manufacture an equivalent. Not too surprising, though, as this filter has such limited application with the most recent almost 50 years old.
            • Doug Y.
              • January 15, 2009
              • 62
              I also thought this filter was for 1965 327/365 HP engines. My buddy has 3 of them .
                • 43247
                Doug------
                1965 327/365 is among the engines I mentioned (i.e. 1963-65 small block with carburetor).
                • Doug Y.
                  • January 15, 2009
                  • 62
                  Thanks Joe I understand .
                  • Michael K.
                    • January 14, 2013
                    • 99
                    Doug------
                    Will this pass judging in a 365hp without a point loss? What is a reasonable price for these? Thanks everyone. mk
                    • Jimmy G.
                      • November 1, 1979
                      • 977
                      It will not pass judging at all Configuration Issues and Finish Issues Personall I would not pay over $ 10 for one as it has nothing to do with an ORIGINAL corvette
                        • 43247
                        Michael------
                        As far as Corvettes go, this is a SERVICE-only air filter element. It is completely different from the original element. My guess would be that it would receive ZERO judging credit. You could use a WIX element and it would fare just as well in judging.
