A/C compressor and Body Drop . Drop slated for Sunday !! - NCRS Discussion Boards
  • Jim S.
    • March 1, 1986
    • 1408
    Body drop slated for this Sunday !!!!
    Does the A/C compressor get in the way ? I seem to recall someone saying it would , but I now can't find that post.
    I sure would like to instal it ahead of time , and line up the pulleys now ,rather then wrestle with it over the fender later !!
    Thanks in advance , and pictures always welcome !!
    JIm
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: A/C compressor and Body Drop . Drop slated for Sunday !!
    Jim,
    Mine was on. Radiator & shroud was off.
    Dom
    • Joseph S.
      National Judging Chairman
      • March 1, 1985
      • 928
      Jim, Yes it is in the way. Line everything up, then remove the alternator, fan and A/C compressor. That will make the body drop a lot easier! Joe
      • Jimmy B.
        • July 31, 1980
        • 584
        On my 65 we had the compressor on, had the radiator in and the fan shroud on, all went perfect, then ..... went to put the lower radiator hose on... there is no way iin "hell" you can get that lower hose on with the shroud in the way, believe me I still have the scars! Good luck on your drop, have extra eyes and go slow....
        Be sure and put the radiator supply tank on before the drop also and the course the cowl ac box, wiper motor, etc
        • Jim S.
          • March 1, 1986
          • 1408
          Jimmy ,
          You scared me . I just went out and looked . Must be a different radiator shroud in 65 than on my 66 . While it doesn't look easy , it doesn't look that hard .(see Photo)Can you elaborate ?
          You also state the A/C compressor was on and did not interfere , while Joseph says it will . I assume that means it is a TIGHT FIT at best .
          Jim
          • Domenic T.
            • January 29, 2010
            • 2452
            Jim,
            I think it's a matter of choice. mine was on but off is much easier as long as it lined up initially.
            DOM
            • Jim S.
              • March 1, 1986
              • 1408
              Thanks guys !
              That's two for ,and one against !
              Anybody else before I decide ??
              Jim
              • Dan H.
                • July 31, 1977
                • 1372
                Jim, had the compressor, alternator, fan, belts, etc., doors, and hood on my 64 Coupe at body drop time. Four guys on each side, a spotter front and rear, went on OK.
                1964 Red FI Coupe, DUNTOV '09
                • Jim S.
                  • March 1, 1986
                  • 1408
                  3 for , one opposed . I think I will go for it .
                  I will be using a 3 ton engine hoist , and have 8 guys to spot and adjust as needed . So I can go slowly and carefully .
                  Thanks to all .and wish me luck !
                  Jim
                  • Jim S.
                    • March 1, 1986
                    • 1408
                    Major success !!!!!
                    Dropped without incident !! A/C compressor, radiator , shroud , all pulleys and belts on before drop .
                    It helped to have a 3 ton engine hoist and 7 guys !
                    Thanks to all who responded ,and to all who gave me the courage to try it with everything on . As always this forum , to me at least , is invaluable !!!!!!!!!!!!!!
                    Jim
                    • Leif A.
                      • August 31, 1997
                      • 3652
                      Greatness!!! Congratulations!! Beautiful car!!
                      Leif
