Engine Lift - NCRS Discussion Boards
Engine Lift
+ More Options
Posts
  • Dino L.
    • February 1, 1996
    • 694
    Engine Lift
    Getting ready to install an engine in a bare chassis, and I have been considering buying a carb plate and bolting it to my aluminum manifold, I have seen many people do this, but I have been concerned about pulling the threads or the motor dropping from lifting it by the intake......any experience or comments? thanks Dino
    Dino Lanno
  • Donald H.
    • November 2, 2009
    • 2589
    Re: Engine Lift
    I'm no expert, but I had the same concern with I installed the engine in dual quad 1960. I ended leaving the intake off and using bolts and chains in the intake bolt holes in the heads. I was installing with the body on the car. The other thing I have seen in some examples was nylon straps on the exhaust manifolds.
    I like you was concerned with a lifting plate bolted to the aluminum manifold.
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
    • Mike M.
      • May 31, 1974
      • 8408
      Re: Engine Lift
      i just lifted a 396 using a carb plate in the aluminum 396 intake manifold. the bbd's are heavier than the sbc's. i even hoisted a 394 olds with the carb plate on an aftermarket aluminum intake. and those oldsmobiles are heavier than a mark IV chevy. go for it. mike
      • Michael G.
        • November 12, 2008
        • 2158
        Re: Engine Lift
        Just one grade 5, 5/16 bolt can lift two Corvettes at once. If you make sure that the bolt is engaged in the manifold at least two bolt diameters (5/8), the aluminum threads will be as strong as the bolt. You may not have that much engagement in these aluminum holes, but 1 1/2 diameters is plenty. Lifting 500 pounds should be no problem whatsoever for four bolts.
        Mike
        1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
        1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
          • 15635
          Re: Engine Lift
          I put the 454 and TH400 together into the old "Orange Crush" 1978 Suburban using a carb plate to the iron intake. I did have minor coolant leaks (note plural) at the intake to head junction when I fired it, but re-torquing the intake manifold resolved them for the next 100K miles.
          I wouldn't do it that way again, but I had access to a huge, and I do mean huge, engine hoist to lift all that over the core support.
          • Gene M.
            • April 1, 1985
            • 4233
            Re: Engine Lift
            I would be sure the the 5/16 threads in the aluminum intake are in good shape. And also be sure to have all slop taken up in the 5/16 hardware prior to lifting. I just can't bring my self to put all that load on a valuable intake manifold when chains attached else were is so easy. Plus, I like a level bar for engine balance.
            • Lynn L.
              1953-55 Team Leader
              • February 1, 2000
              • 162
              Re: Engine Lift
              Use carb plate all the time, my machine shop promotes carb plate use.
              • Dan D.
                • November 5, 2008
                • 1323
                Re: Engine Lift
                Why not just use the exhaust manifold holes? They are 3/8 and will be operating in sheer. You can also pick which ever ones you want to get engine balance.
                -Dan-
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11364
                  Re: Engine Lift
                  Yup...... I always just use the 4 exhaust manifold corners, with a pair of old valve covers to protect the valves.
                  But..... I also agree that aluminum IS quite strong. This Jaguar V12 with Borg Warner cast iron automatic transmission is held up by just 4 integrated aluminum lift rings held to the heads with pairs of 3/8 Grade 3 bolts.
