65 coupe l/hand door mirror update - NCRS Discussion Boards
  • Charles M.
    Infrequent User
    • September 30, 2013
    • 22
    I'm looking to update (NCRS) my door mirror with the correct width mirror retaining ring, does anyone know where I can get one new or used.
    Charles Mirro
  • Russ S.
    • April 30, 1982
    • 2162
    Re: 65 coupe l/hand door mirror update
    I made mine by using the wider ring and slowly and carefully grinding it down all the while using a caliper and checking often.
    • Charles M.
      Infrequent User
      • 22
      Russ, I thought about taking it to a machinist and see what ideas they could come up with, what is the correct width, did you use a bench grinder ?
      Chalie M
      • Russ S.
        • April 30, 1982
        • 2162
        Yes, I used a bench grinder. I have a spare one that measures .100-.105. I don't know if this spare is an original or one that I ground down but if it is a ground down one I would have used an original to copy.
