Need help from Good Wrench - NCRS Discussion Boards
  • Gary C.
    • March 1, 1998
    • 236
    Hi. Posting this here because I know a lot of smart wrenches visit here. Not a corvette, but someone here will give me the answer I need, I am sure.
    I need to remove the pinion nut from my austin healey rear end...I cannot easily figure out how to restrain the ring gear so I can break the nut loose.
    Any advice appreciated.
  • Bill W.
    • March 1, 1980
    • 2000
    Re: Need help from Good Wrench
    use an impact wrench to remove it .
      Use Bill's impact wrench and use a piece of bar or angle stock (with a rag around it) in the ring gear teeth and against the housing to hold the ring gear locked.
      • Paul D.
        • September 30, 1996
        • 491
        Bill has your answer. Maybe in addition to the impact wrench, put a couple bolts through the pinion flange and use a pry bar or large screw driver to hold steady. Better yet, fashion a handle to bolt to the pinion flange. Trying to hold the ring gear will stress it and the pinion needlessly. Chip.
        • Edward J.
          • September 15, 2008
          • 6960
          Gary, also take a center punch and mark the end of pinion gear and the pinion nut so it can be placed back in the same position.
          • Gary C.
            • March 1, 1998
            • 236
            Thanks guys...I had tried my impact, unsuccessfully. I was just not persistent enough. I turned up the air pressure to 150psi and got the job done!!
            Don't know why I have a weakness for sorry British engineering, but I do and now I am restoring a 62 Austin Healey MkII tri carb.
