Picture of heater box/firewall area - NCRS Discussion Boards
  • Charles M.
    Infrequent User
    • September 30, 2013
    • 22
    Trying to get my 65 coupe up to NCRS juding standard (failed for no sealer etc. around replacement heater box/firewall area), can someone post a pic of your heater box area so I can see how neat or not so, it looks around it & firewall area & what type sealer etc. is used.ThanksChalie M
  • Page C.
    • February 1, 1979
    • 802
    Re: Picture of heater box/firewall area
    Hi Charles,
    There is some information in the similar threads at the bottom of this page
    • Patrick T.
      • September 30, 1999
      • 1286
      Originally posted by Charles Mirro (59008)
      Trying to get my 65 coupe up to NCRS judging standard (failed for no sealer etc. around replacement heater box/firewall area), can someone post a pic of your heater box area so I can see how neat or not so, it looks around it & firewall area & what type sealer etc. is used.Thanks Charlie M
      Charles, here is my '67 with plenty of sealer, way more than enough. I think the factory called them "leakers". You don't usually see cars with this much sealer. I'd wonder how much of a deduct this one would get? The "after" picture shows a minimal amount of sealer but it still got me a top flight. I used a black colored roofing cement which goes in a tube. Good Luck.
      Before
      After
      • Harry S.
        • July 31, 2002
        • 5344
        Charlie, if the heater box did not fail the water test, no sealer was added. There is a foam seal there. You should have lost zero points for no sealer.
        • Patrick T.
          • 1286
          Harry, the '67 convertible water leak test at the factory must have been some kind of joke because mine leaks like a sieve when driving in the rain, sealer or no sealer. PT
          • Russ S.
            • April 30, 1982
            • 2163
            It is forty some years old. The sealer gets brittle and shrinks with heat and age. Not surprising that it leaks now.
            • Bill W.
              • March 1, 1980
              • 2000
              Mine had strip calking stuffed in the space . It was dried out and hard when I removed it
              • Bob R.
                • June 30, 2002
                • 1595
                Harry,
                I received a small deduct at the regional recently for no sealer on the heater box?
