Speedo Drive Gear 1957 - NCRS Discussion Boards
  • Robert R.
    Infrequent User
    • June 19, 2011
    • 21
    What would be the correct speedo drive gear for 1957 with a Borg Warner T10, and Diff with 4:11 gears.
    (Number of teeth and /or color?)
  • Terry D.
    • May 31, 1987
    • 2696
    Re: Speedo Drive Gear 1957
    Yellow with 24 teeth
    • Wayne M.
      • March 1, 1980
      • 6414
      Robert, do you mean driven, and not drive gear ?
      My July '65 parts book says 56-60 Corvette (w/4.11 axle) (24 teeth) (nylon) (solid yellow) # 3708143
      But I have the feeling that this is different (in some aspect) from the yellow 24 tooth plastic (nylon ?) gear used in the '61-65+ trannys, part # 3860347, although same number of teeth. I have a couple of those steel driven gears (20 tooth)with a dab of yellow paint, used on the 4.56 ratios [#3860329], and the shaft length is different. Maybe the early B-W used a different adapter fitting.
      c
