1963 Dated Rear Glass - NCRS Discussion Boards
  • Richard S.
    • November 1, 2004
    • 36
    I am looking for a nice set of rear windows with the correct date (pre 10/62). Can rear glass be purchased as a repro without loosing points? Or can a decent set of rear windows be polished if the scratches are only surface?
    Essentially how do you get the right glass for a 63 coupe?
  • Harry S.
    • July 31, 2002
    • 5344
    Re: 1963 Dated Rear Glass
    Rich, look for good original glass, it is out there. Took me 18 months to find a set.
    • Marco H.
      • March 1, 2002
      • 218
      Rich,
      The side and rear glass on the C2 Corvettes is "Tempered", which means, when it breaks, it will crumble in a million small pieces that should not have any sharp edges.
      The windshield is "Laminated", with a clear film between the two layers of glass.
      It has been my experience, that only the laminated glass can be buffed successfully. There are some manufacturers that can etch a nice logo on their glass. Typically, the font on the repro glass appears more fat as compared to the original.
      With regards to points; a new glass with a detectable font may be a wash with an original - showing aging.
      Hope this helps,
      Marco
      • Richard S.
        • November 1, 2004
        • 36
        Marco. Harry,
        All good information...Thanks
        What is the going price for decent used set of glass?
        Where is the best place for a repo set and what does that typically go for?
        Rick
          • 15632
          Originally posted by Marco Hartner (37619)
          Rich,
          Hope this helps,
          Marco
          I respectfully disagree Marco. I successfully polished ALL four pieces of glass on my 1970, and the side glass had scratches deep enough that they could be felt with a fingernail. It can be done, but is exceedingly time consuming.
          • Harry S.
            • July 31, 2002
            • 5344
            I would think somewhere around $300.00 for the pair. You need a very early set so that might be more. I've never looked at reproduction glass.
            • Richard S.
              • November 1, 2004
              • 36
              Terry,
              What was the polishing process you used to remove the scratches?
              Rick
                • 15632
                Originally posted by Richard Stecchi (42887)
                Terry,
                Rick
                There is a commercial glass supplier to the industry near me, and I bought a jar of cerium oxide and a felt buffing wheel. A similar "kit" is available from Eastwood and many other companies.
                Google, or the like, is your friend. There are quite a number of videos on YouTube on this subject and they generally promote a product for sale. There was also an extensive thread on this subject on this board a while back. The 1500 rpm of the polishing is critical. Faster is not better.
                If you aren't prepared to do a little work, don't bother looking. I spent 40 to 60 hours over a couple of weeks on three of the four pieces of glass on the car. I tried to work on them when I was not tired so as not to make a mistake and do more damage. The windshield was fine. The rest was a disaster, but came out fine in the end.
                • Marco H.
                  • March 1, 2002
                  • 218
                  Terry, that is great to hear! The Eastwood kit left deep swirl marks to the point where I tossed the glass in the trash. I have to admit, the scratches I wanted to remove were rather deep, you sure could feel them.
