54 Corvette Drag Link Question - NCRS Discussion Boards
+ More Options
Posts
  • Steve G.
    Infrequent User
    • October 27, 2014
    • 12
    I'm restoring my '54. Yesterday I was trying to remove the drag link from the pitman arm. I removed the outer plug and expected to see a spring. There was no spring. Instead there appears to be another plug. Very strange as it doesn't seem to match any of the exploded parts diagrams I've seen and I have no idea how to get this plug out. Anyone have any ideas? I can post a pic of it if it will help.
  • Jim L.
    • September 30, 1979
    • 1817
    Re: 54 Corvette Drag Link Question
    Try a practical approach: With the front wheels on the ground, rock the steering wheel back and forth. That might pop the plug loose.
    • Steve G.
      Infrequent User
      • October 27, 2014
      • 12
      Thanks Jim. Unfortunately the car is up on blocks at the moment and I don't plan on putting the wheels back on her until all the undercarriage work is done.
      • Tim E.
        • April 1, 1993
        • 360
        Steve - Mine has the spring you're referencing. If you would like a scan of my page of notes from when I took mine apart: tim.ehlers@att.net.
        From the Pitman Arm end, the parts (in order) that I removed were: cotter pin, threaded cap, spring, piston, and then the two bearing caps. All these parts slid out the bore once I removed the threaded cap.
        Does this other plug that you see have a slot and threads as well? Perhaps someone put a solid plug in there instead of the spring thinking it would eliminate some slop in the steering.
        Tim
        • Tim E.
          • April 1, 1993
          • 360
          Here's the document I was trying to upload earlier. The Help Desk got me fixed up....
          54CorvetteDragLinkAssembly.pdf
