This sounds like a stupid question but did the factory use bondo to fill uneven areas before painting? I ask because I am stripping my car and I see what appears to be original paint over bondo. Perhaps it is an old repair but just wondering. If the factory did not use filler, what did they do to smooth over the transition between bonding sections?
Did the factory use Bondo?
Re: Did the factory use Bondo?
Keith -This sounds like a stupid question but did the factory use bondo to fill uneven areas before painting? I ask because I am stripping my car and I see what appears to be original paint over bondo. Perhaps it is an old repair but just wondering. If the factory did not use filler, what did they do to smooth over the transition between bonding sections?
The factory used what they called "putty rub" (an extremely dense fast-curing polyester filler) to deal with uneven areas, gouges, pits, solvent pops in bond joints, etc.
PitFillGrind1024.jpgPitFillApply1024.jpg- Top
Thanks John. Polyester filler is one of the components of Bondo and I am guessing that "putty rub" could also be considered plastic filler or thermoset plastic. So, it might not be surprising to encounter this underneath original factory paint in certain areas.Keith MacRae
NCRS #36692
New Mexico Chapter
1960 290HP FI
2013 427 Convertible
Shade tree mechanic and
B-52 pilot extraordinaire
"Bondo", no, but they did use the bonding agent to fill and level seams and panels. Some bodies have a lot, some have very little. It should be about this color.
Here is an original. Not the filling at the doors.Attached Files- Top
That should have been "Note" the filling at the doors. It is common to find, door gaps, seams, and panels leveled, with the filler.- Top
