C1 Sunvisors - NCRS Discussion Boards
C1 Sunvisors
  • Kenneth F.
    • September 30, 1988
    • 285
    C1 Sunvisors
    I have a set of repro sunvisors, that the pins installed easily in the sides, but the visors do not have a hole for the bolt assembly, and I cannot feel a hole under the vinyl. I used a needle to try to locate the hole in the hardboard, without success. Ideas would be appreciated. Ken
  • Erich C.
    • January 31, 2007
    • 137
    Re: C1 Sunvisors
    Here are some photos of my original '62 d/s visor with the screw locations. Since your working with repo. visors, I wouldn't be surprised that there are no holes. The holes in the sheetmetal clamp are .148 but the screw dia. ( threaded portion ) are only .110 . The holes in the vinyl are .250 .
    Erich
    • Kenneth F.
      • 285
      Re: C1 Sunvisors
      Erich, Would you drill them with a small pilot bit and a higher speed drill motor using light pressure? Thanks for the pics and dimensions. Ken
      • Kenneth F.
        • 285
        Re: C1 Sunvisors
        Erich, I used your dimensions, and the job went well. I appreciate the help. Ken
        • Erich C.
          • January 31, 2007
          • 137
          Re: C1 Sunvisors
          Ken,
          I have not been on site in awhile. I'm glad it worked out for you. I will eventually be replacing my visors. I suspect I will also have to drill holes in my new visors when the time comes.
          Erich
