C4 E-Brake Tag (For Pat Fullam) - NCRS Discussion Boards
  • Ed N.
    • May 16, 2010
    • 1003
    Pat, or anyone else, is this the correct E-Brake tag for 93-96?
    Ed Nieves
    NCRS #51799
  • Keith B.
    • September 15, 2014
    • 1604
    Re: C4 E-Brake Tag (For Pat Fullam)
    Dosent that latter C4 tags have a blue outline around the wordings.
    • Pat F.
      • April 1, 1981
      • 856
      Ed, here is a photo of the one I have.
      The photos show a tag from a 1995. I also have another photo from a 1995 , which is the same, but can not up load it as it exceeds the limits of this forum.
      In my additional photos I have none with a blue border. I have one from a 1990 ZR1 it looks the same as the 1995's
      Is it correct, I think so, but I am always open to comments.
      PAT, Central New Jersey and Florida Chapters
      • Keith B.
        • 1604
        Pat I only saw one C4 with thoes tags on everything and that was a low mile 91 Candna ZR-1. And it's been 5 or so years since then. I could be thinking of something else
        • Pat F.
          • April 1, 1981
          • 856
          Keith, I have problems remembering what I saw an hour ago.
          Thanks for your input.
            • 43286
            Guaranteed known original from 1992 LT1:
            • Ed N.
              • May 16, 2010
              • 1003
              Thank you guys, looks the same to me. Joe, what other tags did your LT1 come with?
              Ed Nieves
              NCRS #51799
              • John M.
                • May 31, 1990
                • 200
                Ed, this tag was attached to the gear shift lever, just below the knob and lock out ring when I took delivery. The attachments are 2 photos as the tag is different on each side. My parking brake tag is identical as the photos already posted. Again, my car is a 1992 LT1 built in June, 1992. John
                • James W.
                  • December 1, 1986
                  • 278
                  My 90 ZR-1 has that same tag, plus a couple others not in the JG
                  jim
                  • Ed N.
                    • May 16, 2010
                    • 1003
                    Thanks John. Is yours an auto or manual?
                    Ed Nieves
                    NCRS #51799
                    • John M.
                      • May 31, 1990
                      • 200
                      Ed, Manual Transmission. John
                      • Ed N.
                        • May 16, 2010
                        • 1003
                        I'm not trying to overcook the grits here, but which is the factory appropriate way of inserting the e-brake tag? Is it the narrow end first or the wider end? How did it come from the factory?
                        Ed Nieves
                        NCRS #51799
                        • Pat F.
                          • April 1, 1981
                          • 856
                          Yo Ed, this is the best I can do concerning the E-Brake Sleeve. It was taken from a 1990 ZR1 that never went into the dealer for prepping. Also I am attaching a couple of photos of the 10 amp fuse and holder for the under the hood lamps. The dealer was to open the holder while doing its prep. The first one with the white holder is from a 1995 and the one with the blue holder is from a 1990.
                          • Ed N.
                            • May 16, 2010
                            • 1003
                            Thanks Pat. I still have the original fuse in mine. Would like to get a packaged one. See you in Lakeland "Homie."
                            Ed Nieves
                            NCRS #51799
                            • Pat F.
                              • April 1, 1981
                              • 856
                              Glad I could help. I will be looking for you in January in Lakeland.
