1969 vent lever housing finish - NCRS Discussion Boards
  • Roger G.
    • October 11, 2012
    • 268
    What is the correct finish on the vent levers/assembly that sits under the console? Part number 3958739. Thanks
    • 43221
    Re: 1969 vent lever housing finish
    Roger------
    Are you referring to the vent levers which are topped with the black plastic knobs? If so, those are natural steel finish (despite what it might say in the P&A catalogs)
    • Roger G.
      • October 11, 2012
      • 268
      Roger------
      Thanks Joe, yes that is what I was referring to. Mine have a rusty patina. What's the best way to restore them? Remove the rust and clear coat?
      • Roger G.
        • October 11, 2012
        • 268
        Roger------
        Here's how it turned out after 24 hours in Evaporust, and clearcoat. The Evaporust is amazing, it was pretty rusty. There is a plastic trim piece that fits along side the slider. I only found one of them laying down in the insulation. I got some black door trim from Autozone that is fairly close, but can this part be sourced?
          • 3416
          Hi Roger,
          I'm missing one of the 4.
          I've been looking for years but haven't found any.
          Even when I see the housing and levers at places like Carlisle, the plastic trim/guides are missing.
          Maybe someone here has some stashed away!
          • Roger G.
            • October 11, 2012
            • 268
            Hi Roger,
            Allan, if they do, you get first dibs
              • 43221
              Alan and Roger------
              The GUIDE is GM #3942780. It was discontinued without supercession in November, 1988. I don't know if it's reproduced, or not. These things fall out VERY EASILY if the console plate is removed. Usually, though, they will be found somewhere under the plate since they fall out so immediately they don't get far.
              • James B.
                • March 1, 1985
                • 217
                Is this the part that's being referenced (on Page 157 - Part Number 15351K)? https://www.paragoncorvette.com/corv...index.html#157
                  • 3416
                  Hi Jim,
                  WELL DONE!
                  From the description it sounds like that's it!
                  I never saw it!
                  • Roger G.
                    • October 11, 2012
                    • 268
                    Hello James...thanks for that...got them ordered!
                    Roger
