C2 heat riser valve gutted? - NCRS Discussion Boards
  • Jim R.
    • June 30, 2001
    • 643
    Has anyone tried to gut a heat riser valve by removing the flapper and pin and can you do it and have the bell crank stay and still move, or when the flapper is removed does that allow the pin and bell crank to slide out. 65 327
    JR
  • Joe R.
    • May 31, 2006
    • 1822
    Re: C2 heat riser valve gutted?
    Hi Jim,
    I don't remember the specifics, but I believe some welding is needed once the internals of the heat riser valve are gutted. Welding may not be the exact term. You can also buy a FI spacer to accomplish this, depending on what your goals are.
    Joe
    • Donald O.
      • May 31, 1990
      • 1588
      I was able to gut mine with a small Dremmel abrasive cut-off. The rod and weight still look and work as designed, but no exhaust is routed to the intake manifold for cold start driveability. Plus, it did help with the dreaded e-10 fuel hot soak percolation issue. In time, perhaps another 20-40 years, the rod may get corroded away (or not, the OE didn't), but since by then I'll be a really really old coot, I won't care.
      DonO
      The light at the end of the tunnel has been turned off.
      • Jim R.
        • June 30, 2001
        • 643
        Hi Don so you removed the entire flapper and left the rod only?
        DonO
        JR
        • Donald O.
          • May 31, 1990
          • 1588
          Yes, the small cut off disc merely cut the flapper disc at it's welds and small pliers broke it off where the disc couldn't reach. New gaskets on install and it has been installed for 12 years like that now.
          DonO
          • Brian M.
            • February 1, 1997
            • 1839
            I did the same as Don years ago without issue. Removed the flapper only.
            • Stuart F.
              • August 31, 1996
              • 4676
              A lot of folks talk about replacing the valve or modifying it, but no one mentions anything about what they went through to drop the exhaust pipe down. I have a 63 with SHP 2-1/2" pipes, and wonder if I can drop the pipe down far enough to get the valve out. I can see dropping the pipe from the hanger at the cross member if I need to in order to gain some more drop at the manifold, but is that enough?
              Stu Fox
              • Russ S.
                • April 30, 1982
                • 2162
                Stu Fox
                Loosening the clamp at the transmission will give enough movement if your pipes aren't rusted together solid.
                • Jim R.
                  • June 30, 2001
                  • 643
                  Yes Stu just enough room to get it out.
                  JR
                  • Stuart F.
                    • August 31, 1996
                    • 4676
                    Thanks Russ. My pipes are very clean aluminized with Stainless steel clamps, so I think I can get it to move.
                    Stu Fox
                    • Stuart F.
                      • August 31, 1996
                      • 4676
                      Thanks Jim. Every time I'm under the car for an oil change I ask myself "should I or shouldn't I ?". I have a spacer that I rounded out the inside of that I want to try.
                      Stu Fox
                      • Timothy B.
                        • April 30, 1983
                        • 5186
                        Can someone tell what the gain is by removing the blade vs just wiring the valve open in hot weather.
                          • 15680
                          If one is in the process of getting their car judged, you don't have to remove and replace the wire every time you enter a judging event. By removing the valve plate, but leaving the shaft, counterweight, and spring attached the heat riser valve has proper original appearance, so no deduction, which would be the case with the FI spacer on a carbureted engine.
                          • Gene M.
                            • April 1, 1985
                            • 4232
                            Less restriction, and even less if the casting is opened up to match the exhaust manifold. It is really not necessary if your Corvette is driven only in pleasant weather.
                            • Stuart F.
                              • August 31, 1996
                              • 4676
                              I have my FI spacer ground out round and I live in central Florida. Just trying to work up enough gumption to make the change. I hate crawling under my car, including for oil changes. My last one was a disaster, what with driving off the ramps, and a pinched o-ring that dumped lots of oil on my driveway. Fortunately, no damage, but I'm getting too old for this stuff.
                              Stu Fox
