First Gear Hammering / Clunking in 66 BB - NCRS Discussion Boards
  • Bill L.
    • March 31, 1985
    • 349
    HI--
    This topic has been discussed before and I have searched the archives for a "Definitive" answer with no luck so -- with advance apologies here is the issue (again):
    I have a low mileage 66 big block coupe --- runs and drives like a top -- no issues at all --
    Took it out for a drive Sunday and pulled onto the street --- started in first gear and pulled away smoothly --- upon full release of the clutch and moderate acceleration I get a VERY LOUD heavy hammering sound---
    I stopped and put the car in reverse and moved it back to the driveway --- went forward again and the same thing -- no hammering in reverse or upon turning into the driveway (hard right turn) --
    This has popped up "over-night" so to speak --- no advance warning --- the car was smooth and powerful one day and now the hammering / clunking ---
    So ---some questions:
    1) Has anyone experienced this exact issue?
    2) If so --- what did you do to alleviate the issue?
    I have suggestions to check all of the U-joints and possibly replace them-- front and rear main -- left and right half shafts --
    Check for a missing weight on the drive shaft --
    Check for deterioration of the large rubber washer on the differential mounting ---
    Check the sway bars front and rear ---
    3) Did I miss anything? --- Has anyone had this issue and if so how did you solve it?
    Thanks in advance for your insight --
    Bill
  • Ken A.
    • July 31, 1986
    • 929
    Re: First Gear Hammering / Clunking in 66 BB
    Sounds like a broken tooth on first gear-lots of work ahead. Have you done a burnout lately?
    • Bill L.
      • March 31, 1985
      • 349
      No I don't do burnouts --- this is a 40+ year old car and does not need that kind of abuse ---
      • Ken A.
        • July 31, 1986
        • 929
        Abuse? That's what a big block was built for, frying tires.
        • Ralph P.
          • January 31, 1990
          • 253
          The differential mount is a prime suspect! ...... When the mount torques up & hits the body it's a definite hammering sound.
          • Bill L.
            • March 31, 1985
            • 349
            Thanks Ralph --- that one is on my list --- pretty straight forward to find it so I may replace that regardless ---
            Regards
            Bill
            • Domenic T.
              • January 28, 2010
              • 2452
              Bill,
              I agree with Ralph.
              Dom
              • Bill L.
                • March 31, 1985
                • 349
                Thanks Dom -- I will get the car up and off the ground this weekend and run the check list -- the differential mount is suspect #1 !!!
                Will let you guys know what I find out.
                Regards
                Bill
