1970 telescoping antenna - NCRS Discussion Boards
  • Kenneth B.
    • August 31, 1984
    • 2089
    Re: 1970 telescoping antenna
    At both those s/ns above I have the note "2 grooves." Since I haven't seen one of these antennas in a while I am not sure what that means, but maybe it means something to you.
    I finally dug mine out & my 70 year old memory is failing me. It is a 2 section antenna NOT a 3 section one as I stated before. The 2 grooves you are eluding to are at the near top of the upper section below a rectangular flat knob about a 1/2 inch. The other groove is about the same distance below the start of the lower section. The stem fits the standard base & has the round with 2 flats cap that screw on the threaded base. The 2 masts themselves are oval shape. Sorry for the confusion. Tip to tip 19 3/4 closed & 32 1/4 extended.
    • Michael F.
      • 745
      I have have had 4 70 vettes over the years and only 1 of them had non fixed antenna, it was original owner car I bought in late 70s I think, somewhere have pictures and copies of paperwork when I bought.
      Michael
      70 Mulsanne Blue LT-1
      03 Electron Blue Z06
      • Kenneth B.
        • August 31, 1984
        • 2089
        HI Mike could you forward the VIN # & a pict. Thanks KEN
        • Michael F.
          • 745
          I will look for it next weekend, it is at families in storage, will forward if I can find it, my current car is fixed antenna and vin is in the 8-8500 range if I remember correct.
          Michael
          • Kenneth B.
            • August 31, 1984
            • 2089
            Originally posted by Thad Lejeune (32187)
            I once owned #7907 it had the telescoping mast. I removed it and still have it!!
            THAD Thanks for the pictures it is just like mine.
            • Kenneth B.
              • August 31, 1984
              • 2089
              This is the 2 mast antenna
              • Kenneth B.
                • August 31, 1984
                • 2089
                One more picture
                • Kenneth B.
                  • August 31, 1984
                  • 2089
                  Still hoping to hear from others. Only had 2 responses beside Terry's & 4 VIN #'S 7601,7907,8031 & 8473.
                  • Kenneth B.
                    • August 31, 1984
                    • 2089
                    #24
                    Trying to keep this alive & I have a thought. My BB VIN # 7601 has a stereo radio & am wandering if that is why it has the 2 mast antenna because over a range of 1000 Corvettes but most have the fixed mast ones. Anyone have a reason that not all had the 2 mast over a certain time? THANKS KEN
                    • Michael F.
                      • 745
                      #25
                      haven't found my pics yet or vin, but the car with it did have a stereo radio, I will continue to look.
                      Michael
                      • Kenneth B.
                        • August 31, 1984
                        • 2089
                        #26
                        I now have 5 known 1970's with the 2 stage mast antenna. VIN #'S 6787, 7601, 7907, 8031, 8473. Anyone know of any others. I talked to 6787 owner who said he has looked for years to find another GM car/truck that these were installed on & can't find any. He thinks these may be test antennas. Any ideas or has anyone seen these on other GM vehicles?
