How to keep the windshield washer working without priming it constantly? - NCRS Discussion Boards
  • Michael J.
    • January 27, 2009
    • 7166
    I had my washer pump rebuilt, and it worked great and stayed primed for several months, but now it is not working if I leave it sitting for an hour or more without priming it again. I have cleaned the filter screen in the tank, replaced fluid, etc., but it still need to be primed if it sits very long. Is there something I am missing? Thanks.
  • Stephen G.
    • January 1, 2002
    • 305
    Re: How to keep the windshield washer working without priming it constantly?
    Michael
    We need more info. What car?
    Steve
    Steve Gansky
    Newtown, (Bucks County) PA
    • Michael J.
      • January 27, 2009
      • 7166
      Oops, sorry, a '64 L76 convertible.
        • 6956
        Mike, Check that the hose connections around the filler cap are good and tight inside and on outside. my 63 is much the same way. It maybe the pump is need of rebuilding.
        • Michael J.
          • January 27, 2009
          • 7166
          Thanks, I will snip off the 1/2" end of the hose that fits on the cap outlet, it is oversized from being old, get a new, tighter fit and see if that helps. The pump was rebuilt 3 months ago.
            • 6956
            That's what I did, they tend to do this once there removed and re-installed of both ends of the cap
              • 11692
              I used a tiny bit of black weatherstrip cement at the hose junctions, and it worked extremely well. No cutting or clipping needed.
              • Michael J.
                • January 27, 2009
                • 7166
                Thanks Patrick, I will try that as well.
                  • 15631
                  ANY air leak in the inlet hose(s) to the pump will allow the liquid to drain back into the reservoir. ALL pump inlet connections MUST be sealed tight or the pump will lose its prime. To paraphrase the Drill Instructor as he read us the Uniform Code of Military Justice "ANY leak no matter how slight ....." Those of you who served will know what word replaced "leak" in that partial sentence, and know what followed those words.
                  • Michael J.
                    • January 27, 2009
                    • 7166
                    Thanks Terry, yes, I remember stuff like that on the Enterprise too. And I am also reminded of my favorite movie, where Gen. Jack D. Ripper said this: Ripper: It just came in on the Red Phone. My orders are for this base to be sealed tight, and that's what I mean to do, seal it tight.
                    So my mission will be to seal it tight, no matter what it takes…...
                    • Pat M.
                      • April 1, 2006
                      • 1582
                      Another thing to check is the little round rubber "umbrella" valves in the pump head. If they are not flexible enough to seal like they should water can siphon back that way, too.
                      • Michael J.
                        • January 27, 2009
                        • 7166
                        • Pat M.
                          • April 1, 2006
                          • 1582
                          That will do it too, the top parts of the pump head must come together airtight to pump and hold prime. One way to test this is to put soapy water around these parts on an assembled pump and blow into the large draw nipple while closing off the small nipples. To test the umbrella valves, put a little water on each side of the part that houses them and it should not drip.
                          You can still get these rubber parts in repair kits if you need them. I don't see them as much in FLAPS but they're still readily available online. Good luck.
                          • Michael J.
                            • January 27, 2009
                            • 7166
                            Thanks and wanted to let you know I installed the LIC external washer repair kit, as the check valve on the inlet of my original rebuilt was the problem leaking off prime. It now works like new, and the resistance to priming it by mouth is a world of difference from the old leaking one. Now I can sleep at night and feel more confident about my PV in ten days.
                            • Pat M.
                              • April 1, 2006
                              • 1582
                              Great news, congrats and good luck on your PV!
