1965 L76 327/365 vac advance B?? - NCRS Discussion Boards
  • Philip A.
    • February 26, 2008
    • 329
    I cannot find in archives. What is the correct can? Has one marked B21. Car is manual shift, no P/S, no P/B, no A/C, no TI. I know the experts on here know this.n thanks.
    Phil
  • Michael J.
    • January 27, 2009
    • 7122
    Re: 1965 L76 327/365 vac advance B??
    B28, IIRC, will give Duke's 2 inch rule.
    • William C.
      • May 31, 1975
      • 6037
      The B-21 is an aftermarket ID, the flange stamp will be "236" (actual part number 1116236) Specs are (distributor degrees and speed 1@460, and 12 @ 1175) So multiply by two for engine rpm and crank advance and you will see the best vacuum can ever for SHP smallblocks. As to how close your B-21 is to the origina,. you need a timing light and a degreed damper to check unless you can find someone with a distributor machine to check it off the car.
      Bill Clupper #618
      • Leif A.
        • August 31, 1997
        • 3631
        Is the engine stock configuration? Have you done a vacuum check off of full manifold vacuum? Michael is correct in stating that the B28 is correct for an original '65 327/365 but a vacuum can doesn't know what your engine is supposed to be or what cam is installed. I would check your engine's actual vacuum at around 650-700RPM and get back with us with those results, then we can suggest the appropriate vacuum can for your specific application.
        Leif
        • Philip A.
          • February 26, 2008
          • 329
          Engine was rebuilt to stock config with correct cam. Distrib has a pointless conversion module which has failed for the second time. I am returning back to points and noticed the vac can numbers and thought to check. I can not tell you the actual vac as engine will not fire due to module and I have not yet converted back to points. Thanks for the replies
          • Michael J.
            • January 27, 2009
            • 7122
            In that case I would get a B28 after you get the points installed and see how it works, sounds like it would work. I have also tried and given up on the "black boxes" of Petronix, etc. and only have stock points. I think Rock Auto still sells the B28 (I bought three a while back), if not NAPA may have it. Good luck!
            • Timothy B.
              • April 30, 1983
              • 5186
              Philip,
              What distributor conversion did you use that failed? Just curious..
              • Philip A.
                • February 26, 2008
                • 329
                Unit was Lectric Limited Breakerless SE conversion.
                • Stuart F.
                  • August 31, 1996
                  • 4676
                  We all have different experiences with electronic conversions. Most of those I have talked with have nothing but praises for them. Perhaps it has to do with who and how they were installed. My Pertronics experiences have been great. I first started with the basic unit with a stock coil, then upgraded to a II unit with their Flamethrower coil running direct 12volt ignition input. I have failed more VAC cans then conversion units (2 to 0). That's why I carry a spare B28 can, but no points spare for many years. I also use a Dyna Flite ball bearing conversion plate and "Blue Dot" advance weight springs. Same as I have had for over 20 years.
                  With points, I had to change plugs frequently as once fouled, for any reason, they wouldn't recover. They would be fine for an L-75, but not an L-76 RPM range. My current set of AC 44's have been in my engine for about 12 years and will pull red line with no sweat anytime.
                  Stu Fox
                  • Philip A.
                    • February 26, 2008
                    • 329
                    Stu
                    thanks for the reply. I have had two failures of the module in 10 years. First install was previous owner and second was me. Install is straight forward and I am confident that is not contributing. Perhaps 5 years is life expectancy of the magnets in the unit. I appreciate the superiority of electronic over points, but this failure rate is not cost effective or acceptable to me. I have already aquired the 236 can, points, condenser, and a rotor. I will see how I fair after conversion back to stock. If I experience the problems you had I will bite the bullet and purchase another electronic conversion.
                    Phil
                    • Stuart F.
                      • August 31, 1996
                      • 4676
                      I guess the main concept that I find important is that once you install points and run your engine they begin to deterioate as the rubbing block wears. So the delema I guess is which will give up first; the points or the magnets. I have been working with Chevy V8's since 1955 and have fiddled with hundreds of sets of points and changed a lot of spark plugs. In the last 42 years I have had only 3 electronic ignition conversions, and the only problem I ever had was a failed inline "pin" connector on a Prestolite (Wards) unit (also used by AMC under a different name). I am batting 1000 with Pertronics, including many conversions I set up for others. But it's your choice of poison, you might say.
                      Good luck.
                      Stu Fox
                      • Philip A.
                        • February 26, 2008
                        • 329
                        Stu
                        I agree with everything you have stated. The Lectric limited unit is a single wire hook-up (the point lead to coil positive). I suspect this unit has internal magnets. I believe the Pertronics and others have multiple wires. This leads me to believe they do not have internal magnets but coil-type posts to create magnetic field. This could explain your past success versus my experience. I put less than 150 miles on the car each year so point wear is not a major concern. If I am unhappy with points performance the next conversion will be a Pertonics. Thanks for replying
                        Phil
                        • Timothy B.
                          • April 30, 1983
                          • 5186
                          Philip,
                          I am surprised by your experience with the Breakerless SE points conversion. I have this unit installed in my 67 distributor and if it ever failed I would just go back to points. Are you using a ballast resistor and a stock coil, I have not heard of many failures with this unit let alone two with the same car, for sure, I would be on the phone with them.
                          • Philip A.
                            • February 26, 2008
                            • 329
                            Tim
                            Ballast resistor and stock coil are in use. How long has your unit been in place? I will be calling them too.
                            Phil
                            • Stuart F.
                              • August 31, 1996
                              • 4676
                              Phil;
                              In post #12 you stated that with the breakerless SE unit you have a single wire hook-up "the point lead to coil positive"??
                              Are sure about this??
                              Stu Fox
