TriPower weld repair and restoration - NCRS Discussion Boards
  • Joe J.
    Infrequent User
    • July 31, 1977
    • 4
    Does anyone know a good shop that can repair a weld made to an alum. intake manifold and restore the intake to factory new / NCRS condition? Joe
    • 43250
    Re: TriPower weld repair and restoration
    Joe------
    Definitely. Jerry MacNeish can do exactly as you wish. Ken Kayser may also be able to do it.
    I believe Jerry's website is z28camaro.com. Ken's contact info can be found in the Driveline. I think he can also be contacted through the member's list on this board.
    • Domenic T.
      • January 29, 2010
      • 2452
      Joe,
      I did my tri power aluminum here in the shop. There are pro's here that will do it for you. Mine broke at the water outlet and it was important to get penetration as the pipe thread puts a lot of pressure on the fitting when it is installed. i did have to re-tap the threads.
      The neat trick that I did after reshaping the aluminum to get the cast texture back, so the repair wouldn't show, was to use about # 30 grit body grinder paper or similar. Turn the grit toward the aluminum and tap the back of the paper with a hammer to texture the repair, it puts the cast look back in the metal, not detectable.
      DOM
      • Joe J.
        Infrequent User
        • July 31, 1977
        • 4
        Originally posted by Domenic Tallarita (51287)
        Joe,
        DOM
        Dom, Thank you for the info. Great idea with the sandpaper. Would never think of that. I think I might be able to handle this. Tks again.
        Joe
        • Joe J.
          Infrequent User
          • July 31, 1977
          • 4
          Dom, Thank you for the info. Great idea with the sandpaper. Would never think of that. I might be able to handle this. Tks again.
          Joe
          • Joe J.
            Infrequent User
            • July 31, 1977
            • 4
            Tks Joe. I checked out Jerry's web site and some of the jobs he did. Nice! Tks for the info.
            Joe
