Positions of white wire ties?? - NCRS Discussion Boards
    • 6941
    Can some post a correct pic of the positions of the white wire ties under the hood. (for 63) they may be the same for later years? Thanks, Ed
    • 6941
    Re: Positions of white wire ties??
    Any one ? I was told at my regional they were wrong, I had the harness that was fitted into the metal bend over tabs and was tied together at 5 locations with the hood cable, my under standing is that its harness hangs with the cable? how about the washer hose on drivers side?
    • Mike M.
      • May 31, 1974
      • 8382
      the hood release bowden cable housing is secured by the metal j-clips, not the wiring harness. the wiring harness is secured to the bowden cable housing with the plastic wire ties. mike
        • 6941
        Mike are the first two white straps drivers side, are the washer hoses and harness hanging from Bowden cable? The aim shows the Bowden cable only in the middle three metal straps and the wiring harness hanging on the two most outer straps.
