In line fuse for high speed blower for AC on 70 big block - NCRS Discussion Boards
  • Willie C.
    • January 6, 2012
    • 37
    Does anyone out there know where the in line fuse for the high speed blower for AC on a 70 454 coupe is?
    Willie
  • Thad L.
    • April 30, 1999
    • 168
    Re: In line fuse for high speed blower for AC on 70 big block
    It's at the horn relay. Driver's side engine compartment by the brake master cyl under hood gutter.
      • 15640
      Find a thick red wire attached to your horn relay and follow that wire toward the rear of the car. I think the in-line fuse you are looking for is just inboard of the brake master cylinder, but I could be wrong. If you follow the red wire you will find it.
      • Jim T.
        • March 1, 1993
        • 5351
        Willie the in-line fuse plastic twist open fuse holder is the only wire coming from the horn relay that has this plastic twist open fuse holder. It takes a 30 type fuse and only supplies electrical for the fan's high speed.
        • Willie C.
          • January 6, 2012
          • 37
          Willie
          Thanks for the info everyone. I found it but the fuse looks ok so now is it likely the switch? Thanks,Willie
            • 15640
            To quote your namesake: "It depends on the meaning of 'it'"
            Sorry I couldn't resist. But it would help if you told us what the problem is. We could guess, but knowing is more fun.
            I looked in the 1970 AIM for C60 and Thad had the right location. Gives new meaning to the old expression "Ask the man who owns one."
            I am just full of useless quotes this morning. Time for lunch.
            • Willie C.
              • January 6, 2012
              • 37
              Hi Terry,
              Fan switch only works on three speeds, the high speed is not working. I thought it may have been the inline fuse since it controls the high speed but not so.
              Willie
                Willie -
                Assuming your "looks OK" means you checked the fuse electrically and it's conducting current, that wire feeds the high blower relay on the evaporator case; if the relay isn't engaging when you select high blower, time to check the relay and the switch.
                • Leif A.
                  • August 31, 1997
                  • 3658
                  What John said. I've had many fuses over the years that "looked OK" but were bad. Pop a new 30 amp in there first and see what happens. The other stuff is much harder to do.
                  Leif
                  • Rich C.
                    • January 1, 1994
                    • 383
                    Willie,
                    Could be the A/C relay!
                    1973 LS-4 454 coupe owned 24 years
                    1996 LT-4 Collector Edition coupe owned 13 months
                    Sierra Nevada Torpedo IPA-currently on tap!
                    • Willie C.
                      • January 6, 2012
                      • 37
                      Thanks for the suggestions everyone, I'm now looking at the relay and the switch.
                      Willie
