54 generator check. - NCRS Discussion Boards
54 generator check.
  • Guy M.
    • November 1, 1993
    • 500
    54 generator check.
    Where do you connect the volt meter at the generator to check the charging voltage? I have 6 volts at the battery. The amp gage never seems to move and I dont know for sure if its charging. I have a NOS regulator. and a strong battery. I herd it should put out a little over 7 volts. I want to check it at the generator. Thanks again.
  • Chris S.
    • January 1, 2000
    • 1068
    Re: 54 generator check.
    did you polarize the generator before starting?
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Eric F.
      • June 30, 2003
      • 319
      Here's some instructions from the stovebolt.com forum http://www.stovebolt.com/ubbthreads/...&Number=592750 It also explains how to polarize the generator. Good luck. Eric
      • Guy M.
        • November 1, 1993
        • 500
        Thanks Chris, sorry for the late response, been out of town. I did not do that and reading up on it I will before re-starting. I hope I didnt do any damage to the regulator.
