C2 standard suspension front coil springs - NCRS Discussion Boards
  • Rocco C.
    Infrequent User
    • January 8, 2014
    • 25
    Would anybody know who sells standaard suspension front coil springs that will pass for ncrs judging? What is the spacing between coils as im trying to determine if they are tired?
  • James W.
    • December 1, 1990
    • 2658
    Re: C2 standard suspension front coil springs
    How does the car sit (stance) with your currently installed springs? High in the front, low in the front or even front-to-rear? I know there was a post a while back mentioned what the free length was. If you haven't done a search of the archives try that first. I believe Long Island Corvette Supply, Paragon, and Corvette Central have them.
    James
    • Debi L.
      Infrequent User
      • September 3, 2013
      • 16
      Rocco,
      i just went through this. Long Island was the only one that was correct. Cost me a lot in shipping as several said they were as original. They were not. Good luck with your project.
      debi
      • Rocco C.
        Infrequent User
        • January 8, 2014
        • 25
        What did you find was NTP with them?
        What did you end up replacing them with?
        • Enzo C.
          • January 12, 2012
          • 534
          Hey Rocco, I recommend you keep your originals as the new styles may raise your front end more than originally specified... Your car sits fine... good Luck
          Enzo Colosimo
          Ncrs Ontario Chapter Chairman 🇨🇦
          ENZ-Z06/67
          • Stephen L.
            • May 31, 1984
            • 3158
            Rocco, you can determine if your springs are "tired" by checking the height dimensions listed in the AIM on page UPC3 A6 (Front trim heights). If they meet that spec you are good to go......
