396 TI Harness - NCRS Discussion Boards
396 TI Harness
  • Mike W.
    • November 1, 1990
    • 71
    396 TI Harness
    I just had the TI system restored for my car. The harness was routed through the opening between the hood hinge and the bracket. I do not believe this is correct because the opening looks too narrow and possibly pinch the harness. I do not have an Assembly Manual for the 65. Does anyone know how the harness is routed as it approaches the hood hinge? Thanks
  • Bill W.
    • March 1, 1980
    • 2000
    Re: 396 TI Harness
    Mike it goes over the top . see photos . What is your serial number ? You can email me at pondpeoplel78@gmail.com DSCN1037.jpgDSCN1036.jpg
    • James W.
      • December 1, 1990
      • 2675
      Re: 396 TI Harness
      Mike,
      It is routed along the right side inner fender below the radiator to expansion tank hose and is routed to the inside of the right side hood hinge. It is positioned in the notch at the top corner of the radiator support and the inner fender where it drapes over the radiator support down to the TI box. It will not get pinched between the hood, hood hinge or the radiator support. I would advise you to invest the money on a '65 AIM, it will show you a lot. Sorry I do not have a good picture to show at this time.
      James West
      • Bill W.
        • March 1, 1980
        • 2000
        Re: 396 TI Harness
        Im sorry I read your post wrong . I dont have good pictures of the front area .
        • Mike W.
          • November 1, 1990
          • 71
          Re: 396 TI Harness
          The harness was actually running through the opening between the hood support and the hood support bracket at the front of the car. I was incorrect in calling it the hood hinge. James, your response makes sense. I am missing a couple of harness clips. By installing the clips the harness will run its proper route. Someone back in the day probably ran it through the hood support bracket because the clip was missing. Thanks guys.
