My 76 used a pre molded 'S' hose from the fuel pump to the fuel line. I was unaware that my 69 would used one also. I am confused!!, also the line under the fuel pump is not bent at a 90 degree angle like I have seen from some other vendors. Mine is more like 45 degree's. I purchased a new pump with the proper logo and #s so I am not sure which is correct. Thank You Roger
Pre Molded 'S' Hose
Re: Pre Molded 'S' Hose
Terry-----
As far as I can tell, the molded fuel supply hose was first used for later 1971. However, it will also work for earlier and I recommend it because "kinking" can occur with non-molded hose (that's probably why GM went to the molded hose in the first place). From what I can determine, these molded hoses were never available from GM in SERVICE.
I can't be 100% sure of the first use of the molded hose, though, since it was never available in SERVICE.In Appreciation of John Hinckley- Top
Hi,
My 71 base engine 71, a January built car had the 's' shaped hose on it.
I've had 2 or 3 reproduction hoses on it that have all weeped gas through the bend in the hose near the fuel pump end of the hose after a year or two..
Might the process used to put the 'bend' permanently in the hose be damaging it?
Alan71 Coupe, 350/270, 4 speed
Chapter Top Flight October 2011- Top
Way back when I first bought my '72 I replaced the fuel line from the steel one to the pump with a piece of hose frommy FLAP. On the way to Carlisle, in the POURING rain it kinked. I now have the correct "S" hose, no problems. Unless judging is an issue, I'd stick with the incorrect hose. I had no fun dealing with that issue in the ran. Have fun!!- Top
Terry-----
My parts stock is not as well organized as yours Joe, but I will look for them over the next week or two. I have some other things interfering with my Corvette activities as the summer winds down in the north-land. There is life outside of corvettes, but I know that is a hard sell here.Terry- Top
I have several of the molded S-shaped fuel hoses with part number labels on them (none for sale). I bought them in the 1972-1973 time frame from the parts counter, so I know it was available in service. My first use of it was to replace the kinked fuel line hose on my LT1.
Terry------
Well, I'd be very interested in what part number you have. I can't find anywhere that any special fuel supply hose (frame line-to-pump) was cataloged in the P&A catalogs for the 68-74 Corvette applications. Also, as far as the PRODUCTION hoses go, it's as follows:
1968-69-------GM #3747662----never available in SERVICE
1970-E71------GM #3933330----never available in SERVICE
L1971-72-------GM #3994298----never available in SERVICE
1973-74--------GM #6271610----never available in SERVICEIn Appreciation of John Hinckley- Top
Terry------
1973-74--------GM #6271610----never available in SERVICETerry- Top
Terry------
Pick tag from 4/16/91 shows part # 14044508 described as "hose"; parts group SP3. I know this is a successive part number as I bought others earlier with a shorter number more appropriate to the 1971 era, but I am not presently able to locate them. There is a good chance the earlier ones were placed in service. I am sure at least one was, and I do know where that one is -- on the 1970.
I might be able arrange for the posting of a picture of the SERVICE and reproduction S-hoses if anyone is really interested. I am told that all the big-box Corvette part vendors market a reproduction.
FWIW: The SERVICE hoses are marked "NBR - CSM" in a close repeat pattern. If I were to use these on a judged car I would remove those markings. I think lacquer thinner would do the job.Terry- Top
Joe,
That's a part number from about 1979. I'm out of town right now. I'll check on it when I get home next week.In Appreciation of John Hinckley- Top
Joe,
Terry-------
GM #14044508 was cataloged as the SERVICE replacement fuel line-to-pump for 1980-81 Corvettes. It was not used as the PRODUCTION part for 1980-81 Corvettes, though. The PRODUCTION part number for 1980-81 as well as 1973-79 was GM #6271610. As far as I can determine, the latter part was never available in SERVICE. However, since the PRODUCTION hose for 1973-81 was the same, that strongly implies that the 14044508 would work for 1973-79 even though it was never cataloged for those year models. I cannot find that there was ever any SERVICE-available predecessor part number to the 14044508. The GM #14044508 was discontinued without supercession in September, 1994.In Appreciation of John Hinckley- Top
