1996 Corvette - NCRS Discussion Boards
1996 Corvette
  • Jim T.
    • March 1, 1993
    • 5351
    1996 Corvette
    Reason for this post is to complain about the Goodyear tires on my 1996 Corvette. The tires make noise which is very distracting on the highway. These tires are old although they have good tread on them. I am considering using a different tire brand when they are replaced. Anyone experience this type if noise on their C4 with Goodyear tires. I replaced the rear tires years ago that had lots of tread left because because of the noise the rear tires made driving on highways.
  • Pat M.
    • April 1, 2006
    • 1586
    Re: 1996 Corvette
    Jim, I have original style Goodyear GSCs on mine and I honestly don't notice unusual/excessive noise with them.
    • Jim T.
      • March 1, 1993
      • 5351
      Re: 1996 Corvette
      Pat you must not have original factory Goodyears on your 96 LT4, if you do then maybe there is something else like wheel bearing problem on my 46,114 mile LT4, but I don't think so.
      • Keith B.
        • March 7, 2008
        • 928
        Re: 1996 Corvette
        I run BF Goodrich tires on my 94. I get zero tire noise
        • Leif A.
          • August 31, 1997
          • 3654
          Re: 1996 Corvette
          Never owned a C4 but I've owned three C5 and they all came from the factory with Goodyear run flats and were noisy as heck. Replaced with Michelins and it was like driving a different car. Quieter, better handling and all around better ride and drive quality. Also, lasted longer...IMHO.
          Leif
          • Pat M.
            • April 1, 2006
            • 1586
            Re: 1996 Corvette
            Jim I ran my factory original wheels and tires for about 7k miles then replaced the wheels and tires with identical oem wheels and tires and never had an issue with either set with noise.
            • Phil W.
              • April 1, 1985
              • 75
              Re: 1996 Corvette
              Jim, I have Cooper tires on my '96 with no noise problems.
              • David H.
                • June 30, 2001
                • 1567
                Re: 1996 Corvette
                My son is pleased with the Continental (non run-flat) tires on his 1996. Seems like you have several good options for non run-flat tires. I replaced the run-flat tires on my 2001&2003 with Michelin non run-flat tires and they were much quieter.
                • Jake D.
                  • August 31, 1984
                  • 134
                  Re: 1996 Corvette
                  Had Firestone Wide Ovals on our LT4....ran the Tail of the Dragon...in the rain....no problems...great tires....would buy them again!!!
                    • 43287
                    Re: 1996 Corvette
                    David------
                    Run flat tires are HIGHLY undesirable for many reasons. I rue the day I ever have to use them. However, as you know, C5 and later Corvettes have no provisions for a spare tire, space-saver or otherwise. So, that means that in most cases, a flat tire is going to mean a tow. When one is 100 miles from nowhere, that's a real problem.
                    • Joe R.
                      • July 31, 1976
                      • 4552
                      Re: 1996 Corvette
                      Just a personal opinion but I would not run a set of Goodyear tires on my 96 if they were given to me and I was paid to ride in the 96!!!!
                      They are noisy, hard, flat spotting miserable tires!!!!
                      As long as Michelin makes tires they will be on my transportation!
                      JR
                      • David H.
                        • June 30, 2001
                        • 1567
                        Re: 1996 Corvette
                        David------
                        Joe,
                        You're right, can be a big problem. I carry a tire plug kit and a small air compressor. I've used it several times on the road, fortunately I did not have to use it on MY vehicles. You have the same flat tire concerns when riding motorcycles - that is when I began carrying air compressor/tire plug kits. The gooey string kits are a pita, I carry a kit that compresses a rubber plug and inserts it into the tire - works very well.
                        • Jim T.
                          • March 1, 1993
                          • 5351
                          Re: 1996 Corvette
                          Pat how many years were your original Goodyears used before you replaced them? What is the age and mileage of the replacement Goodyears? From your previous posts I remember your LT4 has low mileage compared to my LT4. When bought new my LT4 did not have tire noise but it did develop, that is why I replaced the Goodyears on the rear even though there was a good amount of tread left, I don't do burn outs with my LT4, almost all mileage is interstate miles.
                          • Ed N.
                            • May 16, 2010
                            • 1003
                            Re: 1996 Corvette
                            For whatever it's worth, I have original Goodyear GSC tires on my 95 when I show the car and yes they are noisy when I drive on them, and hard. I guess as they age they get hard and subsequently make more noise. I have Goodyear Eagle F1s on my "go" wheels and they are quiet. My 95 has 15,200 miles on it.
                            Ed Nieves
                            NCRS #51799
                            • Pat M.
                              • April 1, 2006
                              • 1586
                              Re: 1996 Corvette
                              Originally posted by Jim Trekell (22375)
                              Pat how many years were your original Goodyears used before you replaced them? What is the age and mileage of the replacement Goodyears? .
                              Jim it's hard to recall but I think I replaced my originals after about 12 years. Current tires are about 14 years old with probably 2k miles on them.
