63 under dash wire - NCRS Discussion Boards
63 under dash wire
  • Brian K.
    • May 31, 2004
    • 358
    63 under dash wire
    I was working on a 63 coupe and noticed a black wire with a green tracer and female connector hanging by the driver side kick panel, right by the headlight circuit breaker. I checked the wiring diagrams in the 63 corvette shop manual and don't see a black wire with green tracers shown. Anyone know what this wire is for ? An option maybe? The vette runs fine and everything works, the radio is aftermarket but this wire is nowhere near the radio. Thanks in advance for any info.
  • Joe R.
    • July 31, 1976
    • 4551
    Re: 63 under dash wire
    Brian,
    Does the 63 have a buzzer tach?
    Could it be the wire to the door switch for the interior lights when the door was opened?
    Is it a PW car?
    JR
    • Brian K.
      • May 31, 2004
      • 358
      Hi Joe, since the interior lights work and the black with green tracer wire has a female connector on it I'll rule that out. Not an Power window car, but the buzzer tach is something to explore. Thanks for your expert opinion Joe , sincerely Brian
      • William C.
        • May 31, 1975
        • 6037
        Well, after looking at the original wiring harness blueprint for a '63 Corvette, I don't find any listing for a black wire with a green stripe on the IP wiring blueprint. Might be useful to find out where it comes from, but It is not likely a factory piece.
        Bill Clupper #618
        • Joe R.
          • July 31, 1976
          • 4551
          Bill and Brian,
          Don't think the buzzer tach was included in the wiring diagram as it was added to some buzzer tachs and not to others. The buzzer had a wire? for the power source from the fuse block, another from the tach to supply ground.
          Could be that power source wire????
          JR
          • Monte M.
            • January 1, 1991
            • 687
            Joe,
            You are correct. It is not part of the speed warning wiring. Those are their own little harness consisting of red and or pinkish, and blue wires that would be nowhere close to that location.
            And yes, pinkish is an official color in my world.
            Brian, can you post a picture so we can actually see the location and connector for ourselves. It just might trigger a memory.
            Best of luck.
            Monte
            • Monte M.
              • January 1, 1991
              • 687
              Brian,
              Is this the wire you are asking about?
              • Brian K.
                • May 31, 2004
                • 358
                Originally posted by Monte Marin (18651)
                Brian,
                [ATTACH=CONFIG]55325[/ATTACH]
                Yes that's the wire!!!! Does anyone know what its for??? Thanks for all the help so far, sincerely Brian
                • Monte M.
                  • January 1, 1991
                  • 687
                  Brian,
                  I have the interior out of my 63 right now. I will dig up the old harness and see if that wire is even there on mine.
                  Is your car an early built car, or was it actually built in 63?
                  Mine is a very early built car built the first few days of November of 62.
                  CORRECTION: I got the picture from a thread about "1963 headlight circuit breaker"
                  Monte
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11345
                    Black/Green is usually related to the speakers on midyears.
                    • Brian K.
                      • May 31, 2004
                      • 358
                      Brian,
                      Monte
                      Hi Monte, the 63 coupe is not my car it's my Uncle's car. I have 66 convertible I'm restoring right now, and I noticed the wire hanging the other day when I did some work on it for him (adjusting the turnsignal switch cable). I never really looked at his VIN to see when his was built (I'll check next time I see the car) The car is Sebring Silver with Dark Blue interior, and thanks again for posting the picture.
                      • Brian K.
                        • May 31, 2004
                        • 358
                        [ATTACH=CONFIG]55326[/ATTACH]
                        Hi Richard, the wire as seen in the photo Monte posted is too far away for the speaker I think. And its a single wire with a female factory connector, I figure it's got to be for an option since it's not listed in the 63 Shop manual wiring diagram.
                        • Monte M.
                          • January 1, 1991
                          • 687
                          Does anybody know what the back up light option lead looks like.
                          Brian, have you tested the wire to see if it is hot, or if it is grounded?
                          Also, I agree, there is no chance it is speaker related.
                          Monte
                          • Richard M.
                            Super Moderator
                            • August 31, 1988
                            • 11345
                            Yes the speaker wire only goes between the radio and the speaker, so if that's in your dash harness, it's not the radio. But radio came to mind based on the color.
                            Look to see where it goes into the harness, and if so follow it forward to the left of the wiper motor. If it looks like it goes through the big grommet in the firewall, check in the engine bay for a telltale.
                            The backup lights get connected to a plug in the engine harness next to the wiper motor. But IIRC the wires get buried in that harness and pass through the grommet mentioned above. Inside, they'd be wrapped in the harness, but come out through the "Body" connector going back to the tail lights, etc in the Rear harness. The body connector rear harness wiring goes behind the driver side kickpanel.
                            Monte
                            Like this switch, only this one has a Powerglide automatic neutral safety also. The Violet is the Neutral Safety, the Green is the Backup Light. It plugs into the engine bay plugs next to(Green) and above(Violet) the wiper motor.
                            (these are pics of a part fellow member John M has on auction)
                            $T2eC16RHJF0FFZ47I7e!BSEDvdMO5g~~60_12.JPG $(KGrHqN,!o0FIKpvPrr-BSEDvfRNQg~~60_12.JPG
                            However, in looking through my old '63 photos, I noticed this one......
                            It's the Park Brake Light switch plug and harness. It's a separate Black wire and a Green wire, but married side by side into a pair. If your green wire was separated from the black wire, it could leave a "trace" of the opposite color on the each one.
                            Maybe?
                            Here are a few more pics of the '63 underdash for reference.....
                            • Timothy B.
                              • April 30, 1983
                              • 5199
                              Brian,
                              If it's the green wire in Monte's picture then it's the horn wire. This wire runs down the steering column and plugs into (I think) a black and gets clipped to the vent cable. Replacement bearings (NOS) have a green colored wire instead of the original black color that runs down the column from the upper bearing/horn contact.
