63 fi crank shaft Keyway - NCRS Discussion Boards
  • Robert B.
    • March 1, 1992
    • 265
    so should should I have a single key way key or 2 smaller keys as my machine shop gave me. ? or does it matter ? seems like it shouldn't matter. ??
    • 43220
    Re: 63 fi crank shaft Keyway
    Robert-------
    You should find that there are TWO end-to-end keyway slots in the crankshaft snout. Each one accepts one of the small keys.
    If your crank has just one long keyway, I would use one long key. However, even in this case, I believe you can use the two small keys you have.
