Gm restoration check valve - NCRS Discussion Boards
  • Dave C.
    • August 31, 2003
    • 82
    Has anybody had any experience recently with the gm restoration vacuum check valves for 68 - 82. I have purchased 3 new ones now and when I hook my Mityvac to the dual nipple side of the valve and plug the adjacent nipple air passes from the single nipple side of the valve - no vacuum building. The Mityvac is does build and hold vacuum. When I do the same test by just sucking one of two I can not get air to pass from the single side. Am I missing something?
  • Rich C.
    • January 1, 1994
    • 383
    Re: Gm restoration check valve
    I don't believe it matters from one to the other on the"2" nipple side. Just that you can blow through the two nipple side to the single. Or pull a vacuum from either of the nipples on the 2 nipple side, while blocking off the other two (the remaining nipple on 2 nipple side and the nipple on the single nipple side) .Is that making sense? Yikes, lot easier to show then describe!
    1973 LS-4 454 coupe owned 24 years
    1996 LT-4 Collector Edition coupe owned 13 months
    Sierra Nevada Torpedo IPA-currently on tap!
