57 oil pan - NCRS Discussion Boards
57 oil pan
  • Greg K.
    • September 30, 1985
    • 35
    57 oil pan
  • Greg K.
    • 35
    Re: 57 oil pan
    Doing some more research on this it looks like teh single groove version is 1960-62. Not really sure what year the single groove version was introduced. Does anyone know what year it was introduced?
    • Rod K.
      • 445
      Re: 57 oil pan
      1957 oil pan did not have a trap door, just the usual for the era horizontal baffle extending rearward from the second step over the pump pickup. It had two vertical grooves on the sides, one a couple of inches high from the bottom located just behind the front corner of the sump, the other the full height of the pan located about the center of the sump. Drain was located in the center of the sump and the bottom is flat. Later pans had a dropped rectangular area around the drain.
      • Edward L.
        • 278
        Re: 57 oil pan
        No trap door pan was used on the 1957 Corvettes. The trap door pan with one groove on the side was used on 1960-1962 solid lifter engines. The 1957 pan has two grooves on the side, one short (1 1/4"), one long, approx. 6 3/4". Email me and I'll send you a picture. edlepelis@verizon.net
        • Loren L.
          • April 30, 1976
          • 4104
          Re: 57 oil pan
          The single groove trap door is 59-61 HP. If your quest is for a '57 trap door oil pan, be sure to include such in your will so that your heirs can continue your quest .......
