1967 spare tire carrier 4 mounting bolts - NCRS Discussion Boards
  • Edward M.
    • January 10, 2014
    • 40
    Can someone supply me with the correct ID for these four bolts. Thank you, Ed
  • Jim S.
    • March 13, 2013
    • 360
    Re: 1967 spare tire carrier 4 mounting bolts
    The latest 67 judging guide calls for the the tub to be secured to the frame by four 1/2" recessed hex-head bolts with separate flat washers. Known head marks are E & EL.
    • R N.
      • May 31, 2002
      • 640
      I believe "D" was another head marking used as well and I've seen both NF and NC thread on these bolts. I'm not sure about this, but was the flat washer used plated?????
      • Michael M.
        • February 1, 1993
        • 606
        Kurt, the " D " head marking bolts I have are 5/16 - 24. The flat washer used matches the head of the bolt.
        • Edward M.
          • January 10, 2014
          • 40
          Thanks for the feedback everyone. Does anyone know if RBW was a possibility? Thanks again, Ed
            • 43287
            Ed------
            RBW (Russell, Birdsall, and Ward) was a fastener supplier to GM during the period. It's very possible they also supplied these screws to the GM for use in this application.
            • Edward M.
              • January 10, 2014
              • 40
              Joe, thank you for the reply but even more so for the education . Ed
