396 Block with RLC Stamp - NCRS Discussion Boards
  • Jack O.
    • July 31, 1996
    • 527
    I have a 396 4 bolt main block, casting 3855962, dated Dec '65, with pad stamped RLC 4433 7. Anyone know what an RLC stamp indicates? Not sure of the 4437, the first 4 may be a double stamp and there's a space between the 3 and 7. Thanks! Jack
    Jack Ottofaro
  • Edward B.
    • March 29, 2013
    • 691
    Re: 396 Block with RLC Stamp
    Jack, post a picture, but I would bet it's a rebuilders stamp. That's not a factory format. Ed
    • Jack O.
      • July 31, 1996
      • 527
      Hi Ed, Took a while but I finally got some pictures of the stamp. They're not the greatest but have a look and let ,e know your thoughts. Thanks, Jack.
      Jack Ottofaro
      • Edward B.
        • March 29, 2013
        • 691
        Yeah, that's not factory and probably some kind of rebuilders stamp like I indicated above.
        Ed
        • Bruce T.
          • February 1, 1978
          • 60
          It sort of looks like there might be broach marks, indicating that the pad was blank before the rebuilder? stamp. If so, that could be a service replacement block, and there would be a Tonowanda stamp on the oil pan rail down by the starter. It would look like a regular pad stamp with date code but with no suffix. Look for something like T1206 down there.
          • Jack O.
            • July 31, 1996
            • 527
            I'm no expert but I believe it does have original broach marks. I'll check the pan rail like you suggest. Thanks.
            Jack Ottofaro
