Replacement Oil Filter - NCRS Discussion Boards
  • Gary L.
    • November 26, 2013
    • 12
    Just picked up a 1959 vette 283, have the winter to go over vehicle. Before I put any miles on the vehicle a few thing I want to deal with, one of which is replacing the fluids, service wheel bearrings etc. at this point engine oil and filter. Which is the recommended replacement # oil filter and spark plug type # and which supplier would be recommended.
    Thanks in advance,
    Gary Logan
    Toronto
  • Jim T.
    • March 1, 1993
    • 5351
    Re: Replacement Oil Filter
    Has your new 1959 been converted to a spin on type filter?
    • Gary L.
      • November 26, 2013
      • 12
      Jim,
      I will be picking the car up on Monday, as it is all original I do not suspect it has been converted from the cartrige to the screw on filter. I may be wrong, in which case if you had information for both filter types, I couldn't go wrong.
      Gary
      • Larry M.
        • January 1, 1992
        • 2701
        • Gary L.
          • November 26, 2013
          • 12
          Larry,
          Thats great, I will confirm the oil filter type on Monday, however I beleive it is the cartridge type on this car. The spark plugs I will stick with the R45 or the R45S stay with the proven. Again that most helpful.
          Gary
