66 Dash Radio Capacitors - NCRS Discussion Boards
  • Tom B.
    • March 1, 2002
    • 140
    How Many Capacitors are at the back of the dash for radio suppresion on the back of cluster ? Does anyone have a pic of location? I know one for each turn indicator and one for ammeter. Is there another by ign. switch. Pics would be greatly appreciated. Thx Tom
  • Stephen L.
    • May 31, 1984
    • 3156
    Re: 66 Dash Radio Capacitors
    If you have an AIM, look under U69 A4 for locations. There are a total of 4 capacitors behind/under the dash.
    • Don H.
      Moderator
      • June 16, 2009
      • 2258
      just as a start, until someone gets you a better photo or illustration, here is a shot of page U69 A5 of the 1965 AIM.
      I imagine that the 66 page shows the same illustration.
      Three capacitors attached to the back of the cluster, one on the ammeter, one on the ignition switch and one on upper right side next to tach.
      • Tom B.
        • March 1, 2002
        • 140
        Don...thx for the pic. There are also 2 at top of cluster for turn indicators that ***** into the wires. Thx
          Tom -
          Nope - the cluster turn indicators don't get any capacitors - that chore is handled by the capacitor that installs over the terminals on the turn signal flasher. The only lamp at the top of the cluster that gets a capacitor with a crimp-on splice connector is the "Brake" warning light. See your Assembly Manual, section U69, sheet A5, item #6.
          • Tom B.
            • March 1, 2002
            • 140
            Does anybody have pics of the back of 66 cluster out of the car so I can see better details of the Capacitors?
            • Stephen L.
              • May 31, 1984
              • 3156
              67 Dash photo......Same as 66. 2 caps shown......
                Tom -
                They're all shown on one sheet in the U69 section of your Assembly Manual.
                • Tom B.
                  • March 1, 2002
                  • 140
                  I'm looking for a good pic of where the capacitor on top bolts to the cluster. The AIM pic is not clear enough. Thx
                  • Jim S.
                    • March 1, 1986
                    • 1398
                    You mean this one ?
                      Tom -
                      The "top" one has the push-pin connector that goes on the "Brake" warning light wire; looks like the photo below.
