screw head? - NCRS Discussion Boards
screw head?
  • Gene M.
    • April 1, 1985
    • 4233
    screw head?
    Screw #9427723 is a black phillips machine #8-32 thread. But what is the head type?
    Also screw #3843505 is a black phillips #8 sheet metal thread. But what is the head type?
    And finally #9414754 is #8 phillips sheet metal I think oval head jackson (#6 head size) but is it black or zinc plated?
    thank you
    • 6958
    Re: screw head?
    Gene, What do they secure?
      • 3422
      Re: screw head?
      Hi Gene,
      The first 2 rang a bell.
      723 is the wiper grill.
      505 is the Astro vent grill.
      Working on the third!
      • Gary C.
        Administrator
        • October 1, 1982
        • 17961
        Re: screw head?
        Gene,
        9414754 found in 1979 & later P&A24; screw oval head cross recess taping, size 8-18 x 3/4 inch long, AB thread style
        Gary
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • Gene M.
          • April 1, 1985
          • 4233
          Re: screw head?
          Originally posted by Gary Chesnut (5895)
          Gene,
          Gary
          Guys, thank you
          The 9414754 is used on 68 for the door and jamb plastic and metal guide plates.
          • Gene M.
            • April 1, 1985
            • 4233
            Re: screw head?
            Alan has the usage correct.
            "Hi Gene,
            Alan"
              • 43287
              Re: screw head?
              thank you
              Gene-----
              Can't be of much help. The 9427723 and 3843505 were never available in SERVICE and I don't otherwise have any specs on them. The 9414754 was once available (until February, 1982). It had a CHROME finish.
              • Gene M.
                • April 1, 1985
                • 4233
                Re: screw head?
                Gene-----
                Thanks Joe, chrome makes sense. I was looking at original screws and I was seeing silver. I assumed zinc, but chrome would be better looking since it is visible as entering and exiting car.
                  • 43287
                  Re: screw head?
                  Gene------
                  I found some old notes of mine in which I somehow came up with the specs on the 3843505. I can't figure out how I did this,but, apparently, I did. This screw is an 8-18, black phosphate-finished. It is FLAT phillips head, countersunk style and the head is 1/4" in OD.
                  • Rich P.
                    • January 12, 2009
                    • 1361
                    Re: screw head?
                    The 2 screws in the pictures Alan posted are very unique. The wiper door grill screw has a Fillister head and usually a self cutting notch Not being reproduced correctly and the astro vent screw has a special taper to the countersunk area and a flat underneath to fit exactly into the grill mounting hole, again not being reproduced correctly.
                    • Gene M.
                      • April 1, 1985
                      • 4233
                      Re: screw head?
                      Yes they are. The heads are smaller than standard #8 hardware. I solved this by turning down the Flathead and Fillister heads of standard screws on a lathe. Followed that by a flat black spray. This is a sickness........!
