Vented vs Non-Vented Breather - NCRS Discussion Boards
  • Bob B.
    • March 1, 2003
    • 831
    Hi all,
    At least for C1s, oil caps are vented on low-HP engines and non-vented on high-HP. This seems backwards or maybe both should be vented? High-revving drag engines have big breathers added to the valve covers. High-revving Corvette engines go the opposite way and eliminate even the tiny vents on the oil cap. Anyone know why this is?
    Bob
    • 15677
    Re: Vented vs Non-Vented Breather
    Drag racing engines and road engines are totally different animals. A drag racing engine doesn't have to meet emission requirements, last for decades and 100K+ miles, or go month/thousands of miles between oil changes.
    This has been discussed before and I believe some C1 engines that didn't require a California closed crankcase ventilation system were equipped with non-vented oil fill caps due to "oil misting" in the engine compartment, so the crankcase vent system was merely the road draft tube. I recall GM wrote a TSB and if a customer complained about oil misting in the engine compartment, the "fix" was to install a non-vented oil fill cap.
    Theoretically, a road draft tube has slight negative pressure relative to the engine compartment, so a vented oil cap allows some fresh air into the crankcase for better purging of blowby gases.
    It's a lousy system that allows much quicker contamination of the oil than later PCV systems, which were initially installed on '61-'62 cars that were destined for sale in California and required on all cars sold in the US beginning in 1963.
    I recommnd retrofitting early engines without PCV systems with the RPO PCV components used on '61-'62 engines though all may not accept them without modifications. The components are available from the various Corvette parts suppliers.
    • Christopher R.
      • March 31, 1975
      • 1599
      [QUOTE=Duke Williams (22045);720462
      Duke[/QUOTE]
      With the PCV system, would you use a vented or non- vented cap?
        • 15677
        A fresh air inlet is absolutely required for a PCV system.
