I know Ive asked a similar question. My carpet is done and Im going to install the shifter. Can the carpet go between the shifter housing and the fiberglass or does the shifter body need to be in contact with the fiberglass. It make a big difference because the beauty ring doesnt cover much carpet. It would seem if the carpet was in between the shifter body and the fiberglass that it would make for a poor. sloppy connection as the screws arent all that big to pull it real tight. If the shifter body needs to be tight against the glass, the carpet would need to be an exact cut so the ring covers it. I dont want to screw this up. Thank again!!
54 shifter to body
Re: 54 shifter to body
Guy
the trim ring goes over the carpet - then the shifter - then the chrome bell cover.
It takes a juggle to get it in.
cut the center hole for the shifter
use an awl or something sharp for the 4 screw holes1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
1957 Corvette - FI 3 sp - Black and Silver- Top
yes - there will be carpet behind the trim ring.1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
