Spax shocks - NCRS Discussion Boards
Spax shocks
  • Harry L.
    • December 22, 2008
    • 370
    Spax shocks
    Will front spax adjustable shocks work well with a 427 engine?
    • 15706
    Re: Spax shocks
    They would work better if you install at all four corners then do some road testing to get the rebound damping dialed into your driving conditions and style.
    • Harry L.
      • December 22, 2008
      • 370
      Re: Spax shocks
      The new Spax Shocks have 28 bump and rebound adjustments. This could be a good thing. I am getting ready to place my order.
        • 15706
        Re: Spax shocks
        For a road car I think the basic rebound only adjustable version will allow you to dial it in. Jounce damping should be fairly soft to allow the suspension to respond to bumps. Rebound must be stronger in order to keep the suspension from over rebounding. The stiffer the ride rate, the more rebound damping is needed.
        American high performance suspensions have typically been "oversprung" and "underdamped", particularly rebound. Most aftermarket springs and shocks are even worse, and the Corvette optional suspensions aren't too hot because they double ride rate, but I don't have enough experience with them to determine if damping is adequate.
        They are tolerable if your roads are fairly smooth.
