Raising the car 1959 - NCRS Discussion Boards
  • John C.
    • September 30, 2001
    • 130
    I have a hydraulic floor jack, not sure how to raise the car where should I place the jack under the car front and back
  • John F.
    • March 23, 2008
    • 2415
    Re: Raising the car 1959
    Under either A-arm on the front and center pumpkin on the rear. Always back-up with jack stands!
    • Art B.
      • 333
      I always raise my C1s as John Ftacek says. By the way, never put the jack under the third arm support bracket at the center front. For a new C1 owner, that is a tempting place to put the jack. If that breaks, you are in for a costly repair.
      • Mike T.
        • January 1, 1992
        • 568
        John, I number of times I put my Hein Werner floor jack under the third arm bearing support bracket and cringed when doing it. Shortly afterwards, I started putting a block of wood alongside but that meant the jack was offcenter. Still worked but not the best way. Can't remember where I saw it, it might have been on the Corvette Forum (and a number of the CF members are also NCRS members) but someone came up with a decent approach for a saddle-shaped wood platform that straddles the third arm bearing support. I need to finally get around to making one up, once I figure out who came up with it, I'll send you the details.
        Mike T. - Prescott AZ.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11334
          Here you go.......
          C1 & C2 Corvettes - Fixture for Jacking a C1 Front End - I've searched high and low for a thread where someone showed a wood fixture that straddled the front steering arm and allowed for use of a single floor jack to raise the front. Can anyone help? :ack:
