There's a leak at the back of the block on my 72 LS5 4-speed coupe.  I've cleaned everything, and when I start the car, it takes a couple of minutes, then a steady drip (every 5-8 seconds) comes from the bottom of the u-portion of the back of the pan and drips down the front face of the flywheel cover.  The flywheel is dry.  When I turn the car off, the dripping stops after the last few make their way down. I'm reasonably certain it is not coming from above (valve cover gasket, etc.) Previous owner may have tried to attack this, because there is a replacement GM oil pan on the car, the majority of bolts have been over-tightened, and orange silicone has  been used everywhere along the pan gaskets.  It looks like "if a little bit is good, a lot is much better." I just spent 3 hours removing orange silicone from the pan and the bottom of the block.
If I need to do a rear main bearing seal I will, but I would rather not if I don't. I don't want to overthink this, so am looking for someone with more experience than I to weigh in on this.
Thanks for your input. I have read extensively in the archives on this, but haven't seen identical symptoms in any other post.
