63 Headlight bucket switch mounting hardware - NCRS Discussion Boards
    • 6956
    I am looking for the correct mounting hardware for the headlight bucket switch under the cluster. self tapping screws? with j-nuts? what are the screw heads and finish? Thanks Ed
  • Michael G.
    • November 12, 2008
    • 2158
    Re: 63 Headlight bucket switch mounting hardware
    I think they are 1/4" self-tapping screws into single-thread u-nuts. Here's the screw head:
    Looks like a zinc plating with black chromate finish. Might be black oxide, but doubtful.
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
    • Timothy B.
      • April 30, 1983
      • 5201
      I also want to add that the switch shown in Mike's picture is not installed correctly as the lip on each side of the switch goes up inside the cluster not under. The only thing visible from under is the switch housing not the screw flange.
        • 6956
        Thanks guys, Tim my 63 switch is mounted like Mikes , I will correct the my screws and mounting..
