1963-1964 Hood - NCRS Discussion Boards
1963-1964 Hood
  • Joe M.
    • February 18, 2010
    • 83
    1963-1964 Hood
    I have two 1963-1964 hoods which I'm trying to research correctly and need some help.Both hoods have 4 hood wedges so its my understanding they are after VIN 6500 based on what've I've been able to find out so far.However, the one hood has a small rivet and the other they larger rivet. If someone could help with approximately what VIN was the small and large rivets? Thanks in advance for the help, I appreciate it.
    Joe
  • Dino L.
    • February 1, 1996
    • 694
    Re: 1963-1964 Hood
    Joe,I am a bit confused on the year of your car.....in your message you state 63-64, I assume you mean when it was made, since the 63 and 64 hoods are radically different because of the cookie sheets and fasteners on the 63 versus drain hole on 64's, the hoods pictured looked like modified 64 hoods where someone has added wedges.....I do not believe 64 had wedges ever...I definitely could be wrong on this....my original hood, Oct 63 built 64 vert does not have wedges and looks identical to your hood from the inside, I cant see the rivets well in the pictures nor do I see the drain hole, but I don't see any 63 typical surround features......they both look like modified 64 hoods to me. Dino
    Dino Lanno
      • 6958
      Re: 1963-1964 Hood
      Joe, I am not sure if anyone really knows about the rivets, as 63 had so many changes with the hood blocks. maybe a few can post with the vin numbers and note if they had a small or large rivets. Might give some what of a clue.I would say just go by the JM as that is really all the judges are looking for ( none,2,4), rivit heads might be a tough call.
      • Gary F.
        • August 29, 2010
        • 248
        Re: 1963-1964 Hood
        Here's a shot of a couple of 63 hood I have. The hood on top has 2 origonal spacers and came from a 17,000 range car. The other 2 holes are filled in with factory filler, The one beneath has 4 and came from a late 10,000 car/ [IMG][/IMG]
          • 6958
          Re: 1963-1964 Hood
          I am working on a 68xx car, no blocks but has big rivets, and the holes for 4 block that are not drilled through, blocked. I know the JM has something about holes being blocked., and my 63 106xx has 4 holes and big rivet heads.
          • Guest
            Re: 1963-1964 Hood
            Agree with Dino
            • Gary F.
              • August 29, 2010
              • 248
              Re: 1963-1964 Hood
              Photo of factory blocked holes from late serial number hood. They can be opened up, if necessary, for the threads are there. [IMG][/IMG]
              • Mike L.
                • January 1, 1986
                • 313
                Re: 1963-1964 Hood
                Early 64 Oct build has larger rivets type. Hoods are two piece some early 64 cars should had might have late 63 type hood bottoms, GM didn't through away parts.
                • Dino L.
                  • February 1, 1996
                  • 694
                  Re: 1963-1964 Hood
                  No evidence of any 63 parts on my hood...hood surround inner, fiberglass outer, no wedges, no extra holes...vin 38XX 1964
                  Dino Lanno
                  • John D.
                    • December 1, 1979
                    • 5507
                    Re: 1963-1964 Hood
                    THis may be the first time we discussed this. I have seen two different size rivet heads on hoods with wedges/blocks. Wish I could tell you what my 9900 car has but it's buried at the moment.
                    Jorjorian asked me the size of the rivets of my March 63 long ago.
                    Maybe he will chirp in and help although it appears Lombardi already knows the info. I for one do not. JD
                    • Joe M.
                      • February 18, 2010
                      • 83
                      Re: 1963-1964 Hood
                      I hope these additional pictures of both hoods are able to clear things up on the rivet size.The one hood has been undercoated back in the day so its hard seeing some of the detail in the pictures.The undercoated hood was in storage for over 20+ years until last week.
                      • Guest
                        Re: 1963-1964 Hood
                        Still look like bastardized 1964 hoods
                        • Dino L.
                          • February 1, 1996
                          • 694
                          Re: 1963-1964 Hood
                          Joe.....you need to clarify are you trying to figure out what a 1963 or 1964 hood looks like, because every picture you have shared is of a 1964 hood.....that as Rick has pointed out has been bastardized......it don't matter the rivet size...if your trying to mount a 64 hood on a 63......if you are trying to figure out a correct 64 hood, please state that and what your VIN is....either way the hoods you have both look like they have been messed with for a 64, and totally wrong for a 63
                          Dino Lanno
