65 bb oil pressure copper line - NCRS Discussion Boards
  • Rocco C.
    Infrequent User
    • January 8, 2014
    • 25
    Can anyone tell me if the copper wire that connects to the temperature gauge runs clockwise when it comes out of the firewall or counterclockwise
  • Bill W.
    • March 1, 1980
    • 2000
    Re: 65 bb temp sending unit copper wire
    not sure I understand the question
      • 43246
      Bill------
      I'm sure. I definitely don't understand it.
      • Rocco C.
        Infrequent User
        • January 8, 2014
        • 25
        Bill------
        The temp sending unit has a copper wire attached to it. When it comes out of the firewall the wire is in a spring like formation. When your looking down at that spring like formation does it circle clockwise or counterclockwise?
        hope this helps
        • Keith B.
          • March 7, 2008
          • 928
          The oil pressure line runs like you discribe. The wire for the temp sender comes out of the engine harnes by the wiper motor and runs along the valve cover and plugs into the sender
          • James W.
            • December 1, 1990
            • 2664
            Rocco,
            If you are talking about the oil pressure tubing between the block and the gauge here is a picture. I can't recall any "coiled" wire for the temp sending unit/
            Hope this helps???
            James West
            • Rocco C.
              Infrequent User
              • January 8, 2014
              • 25
              Thank you
              Counterclockwise like the assembly manual shows
              • Don H.
                Moderator
                • June 16, 2009
                • 2269
                since the mystery was solved, I changed the thread title for more successful future searching.
